Retrieve users with the most I/O activity
GET /storage/volumes/{volume.uuid}/top-metrics/users
Introduced In: 9.10
Retrieves a list of users with the most IO activity.
volume.uuid  |
string  |
path  |
True  |
Volume UUID  |
top_metric  |
string  |
query  |
False  |
IO activity type
iops.error.lower_bound  |
integer  |
query  |
False  |
Filter by iops.error.lower_bound  |
iops.error.upper_bound  |
integer  |
query  |
False  |
Filter by iops.error.upper_bound  |
iops.read  |
integer  |
query  |
False  |
Filter by iops.read  |
iops.write  |
integer  |
query  |
False  |
Filter by iops.write  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
volume.name  |
string  |
query  |
False  |
Filter by volume.name  |
user_id  |
string  |
query  |
False  |
Filter by user_id  |
user_name  |
string  |
query  |
False  |
Filter by user_name  |
throughput.read  |
integer  |
query  |
False  |
Filter by throughput.read  |
throughput.write  |
integer  |
query  |
False  |
Filter by throughput.write  |
throughput.error.lower_bound  |
integer  |
query  |
False  |
Filter by throughput.error.lower_bound  |
throughput.error.upper_bound  |
integer  |
query  |
False  |
Filter by throughput.error.upper_bound  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
notice  |
Optional field that indicates why no records are returned by the volume activity tracking REST API.  |
num_records  |
integer  |
Number of records.  |
records  |
array[top_metrics_user]  |
    "next": {
      "href": "/api/resourcelink"
  "notice": {
    "code": "111411207",
    "message": "No read/write traffic on volume."
  "records": [
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 4,
        "write": 8
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 10,
        "write": 7
      "user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "user_name": "James",
      "volume": {
        "name": "volume1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
notice
code  |
string  |
Warning code indicating why no records are returned.  |
message  |
string  |
Details why no records are returned.  |
top_metric_value_error_bounds
lower_bound  |
integer  |
Lower bound of the nominal value of a metric.  |
upper_bound  |
integer  |
Upper bound of the nominal value of a metric.  |
iops
error  |
read  |
integer  |
Average number of read operations per second.  |
write  |
integer  |
Average number of write operations per second.  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
throughput
error  |
read  |
integer  |
Average number of read bytes received per second.  |
write  |
integer  |
Average number of write bytes received per second.  |
volume
_links  |
name  |
string  |
The name of the volume.  |
uuid  |
string  |
top_metrics_user
Information about a user's IO activity.
iops  |
svm  |
throughput  |
user_id  |
string  |
User ID of the user.  |
user_name  |
string  |
Name of the user.  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
