REST API reference
Retrieve users with the most I/O activity
GET /storage/volumes/{volume.uuid}/top-metrics/users
Introduced In: 9.10
Retrieves a list of users with the most IO activity.
volume.uuid
string
path
True
Volume UUID
top_metric
string
query
False
IO activity type
  • Default value: 1
  • enum: ["iops.read", "iops.write", "throughput.read", "throughput.write"]
user_name
string
query
False
Filter by user_name
volume.name
string
query
False
Filter by volume.name
throughput.read
integer
query
False
Filter by throughput.read
throughput.write
integer
query
False
Filter by throughput.write
throughput.error.lower_bound
integer
query
False
Filter by throughput.error.lower_bound
throughput.error.upper_bound
integer
query
False
Filter by throughput.error.upper_bound
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
iops.error.lower_bound
integer
query
False
Filter by iops.error.lower_bound
iops.error.upper_bound
integer
query
False
Filter by iops.error.upper_bound
iops.read
integer
query
False
Filter by iops.read
iops.write
integer
query
False
Filter by iops.write
user_id
string
query
False
Filter by user_id
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
incomplete_response_reason
Indicates that the metric report provides incomplete data.
notice
notice
Optional field that indicates why no records are returned by the volume activity tracking REST API.
num_records
integer
Number of records.
records
array[top_metrics_user]
    "next": {
      "href": "/api/resourcelink"
  "incomplete_response_reason": {
    "code": "111411207",
    "message": "Partial data has been returned for this metric report. Reason: The activity tracking report for this volume is not available because the system is busy collecting tracking data."
  "notice": {
    "message": "No read/write traffic on volume."
  "num_records": 1,
  "records": [
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 4,
        "write": 8
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 10,
        "write": 7
      "user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "user_name": "James",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
124518405
Volume activity tracking is not supported on volumes that contain LUNs.
124518407
Volume activity tracking is not supported on FlexCache volumes.
124518408
Volume activity tracking is not supported on audit staging volumes.
124518409
Volume activity tracking is not supported on object store server volumes.
124518410
Volume activity tracking is not supported on SnapMirror destination volumes.
124518411
Enabling or disabling volume activity tracking is not supported on individual FlexGroup constituents.
124518412
Volume activity tracking is not supported on SnapLock volumes.
124518414
Volume activity tracking is not supported on volumes that contain NVMe namespaces.
124518415
Failed to get the volume activity tracking report on volume volume.name in SVM svm.name.
124518416
Internal error. Volume activity tracking report timed out for volume volume.name in SVM svm.name.
124518417
Volume wildcard queries are not supported for activity tracking reports.
124518418
The activity tracking report for volume volume.name in SVM svm.name returned zero records. Check whether the volume has read/write traffic. Refer to the REST API documentation for more information.
124519413
Volume activity tracking is not enabled on the volume.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Warning code indicating why partial data was reported.
message
string
A message describing the reason for partial data.
notice
code
string
Warning code indicating why no records are returned.
message
string
Details why no records are returned.
top_metric_value_error_bounds
lower_bound
integer
Lower bound of the nominal value of a metric.
upper_bound
integer
Upper bound of the nominal value of a metric.
iops
error
read
integer
Average number of read operations per second.
write
integer
Average number of write operations per second.
self
svm
_links
_links
name
string
uuid
string
throughput
error
read
integer
Average number of read bytes received per second.
write
integer
Average number of write bytes received per second.
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
top_metrics_user
Information about a user's IO activity.
iops
iops
svm
svm
throughput
throughput
user_id
string
User ID of the user.
user_name
string
Name of the user.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
