Retrieve an event filter rule
Retrieves an event filter rule to view the criteria used for filtering events within the system. This helps you manage and monitor specific events based on predefined rules.
HTTP method and endpoint
GET /support/ems/filters/{name}/rules/{index}
Introduced in
ONTAP 9.6
Related ONTAP commands
event filter show
name |
string |
path |
True |
Filter name |
index |
string |
path |
True |
Filter index |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
"href": "/api/resourcelink"
"index": 1,
"message_criteria": {
"related": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
_links
related |
message_criteria
_links |
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
