Retrieve an event filter rule
GET /support/ems/filters/{name}/rules/{index}
Introduced In: 9.6
Retrieves an event filter rule.
Related ONTAP commands
event filter show
name  |
string  |
path  |
True  |
Filter name  |
index  |
string  |
path  |
True  |
Filter rule index  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
index  |
integer  |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.  |
message_criteria  |
Matching message definitions for the filter. A property must be specified.  |
parameter_criteria  |
array[parameter_criteria]  |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters.  |
type  |
string  |
Rule type  |
      "href": "/api/resourcelink"
  "index": 1,
  "message_criteria": {
      "related": {
    "name_pattern": "wafl.*",
    "severities": "emergency,alert,error",
    "snmp_trap_types": "standard,built_in"
  "parameter_criteria": [
      "name_pattern": "vol",
      "value_pattern": "cloud*"
  "type": "include"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
_links
related  |
message_criteria
_links  |
name_pattern  |
string  |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.  |
severities  |
string  |
A comma-separated list of severities or a wildcard.  |
snmp_trap_types  |
string  |
A comma separated list of snmp_trap_types or a wildcard.  |
parameter_criteria
Criterion used for parameter based filtering
name_pattern  |
string  |
Parameter name pattern. Wildcard character '*' is supported.  |
value_pattern  |
string  |
Parameter value pattern. Wildcard character '*' is supported.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
