REST API reference
Retrieve an event filter rule
Retrieves an event filter rule to view its configuration and settings. This helps you manage and troubleshoot event notifications effectively.
HTTP method and endpoint
GET /support/ems/filters/{name}/rules/{index}
Introduced in
ONTAP 9.6
  • event filter show
name
string
path
True
Filter name
index
string
path
True
Filter index
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
Matching message definitions for the filter. A property must be specified.
type
string
Rule type
      "href": "/api/resourcelink"
  "index": 1,
  "message_criteria": {
      "related": {
    "name_pattern": "callhome.*",
    "severities": "error,informational",
    "snmp_trap_types": "standard|built_in"
  "type": "include"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
related
message_criteria
_links
_links
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
