REST API reference
Retrieve SVM migration status
Retrieves the current status of an SVM migration, helping you monitor and manage data movement processes.
HTTP method and endpoint
GET /svm/migrations
Introduced in
ONTAP 9.10
Usage notes
Retrieves the SVM migration status.
  • vserver migrate show
uuid
string
query
False
Filter by uuid
current_operation
string
query
False
Filter by current_operation
time_metrics.cutover_trigger_time
string
query
False
Filter by time_metrics.cutover_trigger_time
time_metrics.cutover_complete_time
string
query
False
Filter by time_metrics.cutover_complete_time
time_metrics.start_time
string
query
False
Filter by time_metrics.start_time
time_metrics.cutover_start_time
string
query
False
Filter by time_metrics.cutover_start_time
time_metrics.last_resume_time
string
query
False
Filter by time_metrics.last_resume_time
time_metrics.last_pause_time
string
query
False
Filter by time_metrics.last_pause_time
time_metrics.end_time
string
query
False
Filter by time_metrics.end_time
messages.message
string
query
False
Filter by messages.message
messages.code
integer
query
False
Filter by messages.code
state
string
query
False
Filter by state
restart_count
integer
query
False
Filter by restart_count
last_operation
string
query
False
Filter by last_operation
auto_cutover
boolean
query
False
Filter by auto_cutover
auto_source_cleanup
boolean
query
False
Filter by auto_source_cleanup
source.cluster.name
string
query
False
Filter by source.cluster.name
source.cluster.uuid
string
query
False
Filter by source.cluster.uuid
source.svm.uuid
string
query
False
Filter by source.svm.uuid
source.svm.name
string
query
False
Filter by source.svm.name
last_failed_state
string
query
False
Filter by last_failed_state
destination.volume_placement.aggregates.uuid
string
query
False
Filter by destination.volume_placement.aggregates.uuid
destination.volume_placement.aggregates.name
string
query
False
Filter by destination.volume_placement.aggregates.name
destination.ipspace.uuid
string
query
False
Filter by destination.ipspace.uuid
destination.ipspace.name
string
query
False
Filter by destination.ipspace.name
point_of_no_return
boolean
query
False
Filter by point_of_no_return
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_migration]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "check_only": null,
      "current_operation": "string",
      "destination": {
        "ipspace": {
          "name": "exchange",
        "volume_placement": {
          "aggregates": [
              "name": "aggr1",
      "last_failed_state": "string",
      "last_operation": "string",
      "messages": [
          "message": "string"
      "restart_count": 0,
      "source": {
        "cluster": {
          "name": "cluster1",
        "svm": {
          "name": "svm1",
      "state": "string",
      "time_metrics": {
        "cutover_complete_time": "2020-12-02T19:30:19-08:00",
        "cutover_start_time": "2020-12-02T18:20:19-08:00",
        "cutover_trigger_time": "2020-12-02T19:15:19-08:00",
        "end_time": "2020-12-02T19:36:19-08:00",
        "last_pause_time": "2020-12-02T18:50:19-08:00",
        "last_resume_time": "2020-12-02T18:54:19-08:00",
        "start_time": "2020-12-02T18:36:19-08:00"
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
aggregates
Aggregate
_links
_links
name
string
uuid
string
volume_placement
Optional property to specify the source volume placement in the destination.
aggregates
array[aggregates]
Optional property used to specify the list of desired aggregates to use for volume creation in the destination.
destination
Destination cluster details for the SVM migration.
ipspace
ipspace
volume_placement
volume_placement
messages
Specifies failure codes and messages.
code
integer
Message code
message
string
Detailed message of warning or error.
cluster
Source cluster for the SVM migration.
_links
_links
name
string
uuid
string
svm
Source SVM
_links
_links
name
string
The name of the SVM.
uuid
string
source
Source cluster details for the SVM migration.
cluster
cluster
svm
svm
Source SVM
time_metrics
Various time metrics details
string
Cutover end time
cutover_start_time
string
Cutover start time
string
Cutover trigger time
end_time
string
Migration end time
last_pause_time
string
Last migration pause time
last_resume_time
string
Last migration resume time
start_time
string
Migration start time
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
auto_cutover
boolean
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
auto_source_cleanup
boolean
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
current_operation
string
destination
destination
last_failed_state
string
Indicates the state of the migration.
last_operation
string
messages
array[messages]
Errors and warnings returned/displayed during migration.
point_of_no_return
boolean
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted.
restart_count
integer
Number of times SVM migration was restarted since initially started.
source
source
state
string
time_metrics
time_metrics
uuid
string
SVM migration UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
