Retrieve the SVM migration status
Accesses the status of an SVM migration to monitor and track its progress.
HTTP method and endpoint
GET /svm/migrations
Introduced in
ONTAP 9.10
Usage notes
Retrieves the SVM migration status.
Related ONTAP commands
vserver migrate show
time_metrics.start_time |
string |
query |
False |
Filter by time_metrics.start_time |
time_metrics.cutover_complete_time |
string |
query |
False |
Filter by time_metrics.cutover_complete_time |
time_metrics.last_resume_time |
string |
query |
False |
Filter by time_metrics.last_resume_time |
time_metrics.last_pause_time |
string |
query |
False |
Filter by time_metrics.last_pause_time |
time_metrics.cutover_start_time |
string |
query |
False |
Filter by time_metrics.cutover_start_time |
time_metrics.cutover_trigger_time |
string |
query |
False |
Filter by time_metrics.cutover_trigger_time |
time_metrics.end_time |
string |
query |
False |
Filter by time_metrics.end_time |
source.cluster.name |
string |
query |
False |
Filter by source.cluster.name |
source.cluster.uuid |
string |
query |
False |
Filter by source.cluster.uuid |
source.svm.uuid |
string |
query |
False |
Filter by source.svm.uuid |
source.svm.name |
string |
query |
False |
Filter by source.svm.name |
auto_cutover |
boolean |
query |
False |
Filter by auto_cutover |
state |
string |
query |
False |
Filter by state |
auto_source_cleanup |
boolean |
query |
False |
Filter by auto_source_cleanup |
restart_count |
integer |
query |
False |
Filter by restart_count |
last_operation |
string |
query |
False |
Filter by last_operation |
current_operation |
string |
query |
False |
Filter by current_operation |
uuid |
string |
query |
False |
Filter by uuid |
messages.code |
integer |
query |
False |
Filter by messages.code |
messages.message |
string |
query |
False |
Filter by messages.message |
last_failed_state |
string |
query |
False |
Filter by last_failed_state |
point_of_no_return |
boolean |
query |
False |
Filter by point_of_no_return |
destination.ipspace.name |
string |
query |
False |
Filter by destination.ipspace.name |
destination.ipspace.uuid |
string |
query |
False |
Filter by destination.ipspace.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_migration] |
"next": {
"href": "/api/resourcelink"
"records": [
"check_only": null,
"current_operation": "string",
"destination": {
"ipspace": {
"name": "exchange",
"last_failed_state": "string",
"last_operation": "string",
"messages": [
"message": "string"
"restart_count": 0,
"source": {
"cluster": {
"name": "cluster1",
"svm": {
"name": "svm1",
"state": "string",
"time_metrics": {
"cutover_complete_time": "2020-12-02T19:30:19-08:00",
"cutover_start_time": "2020-12-02T18:20:19-08:00",
"cutover_trigger_time": "2020-12-02T19:15:19-08:00",
"end_time": "2020-12-02T19:36:19-08:00",
"last_pause_time": "2020-12-02T18:50:19-08:00",
"last_resume_time": "2020-12-02T18:54:19-08:00",
"start_time": "2020-12-02T18:36:19-08:00"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
aggregates
_links |
name |
string |
uuid |
string |
aggregate
Aggregate to use for volume creation.
_links |
name |
string |
uuid |
string |
volume
Property indicating the source volume.
_links |
name |
string |
The name of the volume. |
uuid |
string |
volume_aggregate_pairs
Volume-aggregate pair information.
aggregate |
Aggregate to use for volume creation. |
volume |
Property indicating the source volume. |
volume_placement
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET.
aggregates |
array[aggregates] |
Optional property used to specify the list of desired aggregates to use for volume creation in the destination. |
volume_aggregate_pairs |
array[volume_aggregate_pairs] |
Optional property used to specify the list of desired volume-aggregate pairs in the destination. |
destination
Destination cluster details for the SVM migration.
ipspace |
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Network interface on the source SVM.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
name |
string |
Name of node on which the port is located. |
port
Port to use for IP interface placement on the destination SVM.
_links |
name |
string |
node |
uuid |
string |
ip_interfaces
IP interface and network port pair information.
interface |
Network interface on the source SVM. |
port |
Port to use for IP interface placement on the destination SVM. |
svm_migration_ip_interface_placement
Optional property used to specify the list of source SVM's IP interface and network port pairs in the destination for migrating the source SVM IP interfaces. Note that the SVM migration does not perform any reachability checks on the IP interfaces provided.
ip_interfaces |
array[ip_interfaces] |
List of source SVM's IP interface and port pairs on the destination for migrating the source SVM's IP interfaces. |
messages
Specifies failure codes and messages.
code |
integer |
Message code |
message |
string |
Detailed message of warning or error. |
cluster
Source cluster for the SVM migration.
_links |
name |
string |
uuid |
string |
svm
Source SVM
_links |
name |
string |
The name of the SVM. |
uuid |
string |
source
Source cluster details for the SVM migration.
cluster |
Source cluster for the SVM migration. |
svm |
Source SVM |
time_metrics
Various time metrics details
string |
Cutover end time |
string |
Cutover start time |
string |
Cutover trigger time |
end_time |
string |
Migration end time |
last_pause_time |
string |
Last migration pause time |
last_resume_time |
string |
Last migration resume time |
start_time |
string |
Migration start time |
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
auto_cutover |
boolean |
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover". |
boolean |
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover. |
current_operation |
string |
destination |
Destination cluster details for the SVM migration. |
last_failed_state |
string |
Indicates the state of the migration. |
last_operation |
string |
messages |
array[messages] |
Errors and warnings returned/displayed during migration. |
boolean |
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted. |
restart_count |
integer |
Number of times SVM migration was restarted since initially started. |
source |
Source cluster details for the SVM migration. |
state |
string |
time_metrics |
Various time metrics details |
uuid |
string |
SVM migration UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
