REST API reference
Retrieve the SVM migration status
GET /svm/migrations
Introduced In: 9.10
Retrieves the SVM migration status.
  • vserver migrate show
state
string
query
False
Filter by state
post_ponr_retry_count
integer
query
False
Filter by post_ponr_retry_count
  • Introduced in: 9.17
auto_source_cleanup
boolean
query
False
Filter by auto_source_cleanup
source.cluster.name
string
query
False
Filter by source.cluster.name
source.cluster.uuid
string
query
False
Filter by source.cluster.uuid
source.svm.name
string
query
False
Filter by source.svm.name
source.svm.uuid
string
query
False
Filter by source.svm.uuid
point_of_no_return
boolean
query
False
Filter by point_of_no_return
destination.ipspace.name
string
query
False
Filter by destination.ipspace.name
destination.ipspace.uuid
string
query
False
Filter by destination.ipspace.uuid
uuid
string
query
False
Filter by uuid
current_operation
string
query
False
Filter by current_operation
messages.message
string
query
False
Filter by messages.message
messages.code
string
query
False
Filter by messages.code
auto_cutover
boolean
query
False
Filter by auto_cutover
restart_count
integer
query
False
Filter by restart_count
throttle
integer
query
False
Filter by throttle
  • Introduced in: 9.12
last_operation
string
query
False
Filter by last_operation
time_metrics.start_time
string
query
False
Filter by time_metrics.start_time
time_metrics.last_resume_time
string
query
False
Filter by time_metrics.last_resume_time
time_metrics.last_pause_time
string
query
False
Filter by time_metrics.last_pause_time
time_metrics.last_post_ponr_retry_time
string
query
False
Filter by time_metrics.last_post_ponr_retry_time
time_metrics.cutover_start_time
string
query
False
Filter by time_metrics.cutover_start_time
time_metrics.cutover_trigger_time
string
query
False
Filter by time_metrics.cutover_trigger_time
time_metrics.cutover_complete_time
string
query
False
Filter by time_metrics.cutover_complete_time
time_metrics.end_time
string
query
False
Filter by time_metrics.end_time
last_failed_state
string
query
False
Filter by last_failed_state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_migration]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "check_only": true,
      "current_operation": "string",
      "destination": {
        "ipspace": {
          "name": "Default",
      "last_failed_state": "string",
      "last_operation": "string",
      "messages": [
          "code": "string",
          "message": "string"
      "post_ponr_retry_count": 0,
      "restart_count": 0,
      "source": {
        "cluster": {
          "name": "cluster1",
        "svm": {
          "name": "svm1",
      "state": "string",
      "throttle": 0,
      "time_metrics": {
        "cutover_complete_time": "2020-12-02 19:30:19 -0800",
        "cutover_start_time": "2020-12-02 18:20:19 -0800",
        "cutover_trigger_time": "2020-12-02 19:15:19 -0800",
        "end_time": "2020-12-02 19:36:19 -0800",
        "last_pause_time": "2020-12-02 18:50:19 -0800",
        "last_post_ponr_retry_time": "2020-12-02 19:30:19 -0800",
        "last_resume_time": "2020-12-02 18:54:19 -0800",
        "start_time": "2020-12-02 18:36:19 -0800"
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
aggregates
Aggregate
_links
_links
name
string
uuid
string
aggregate
Aggregate to use for volume creation.
_links
_links
name
string
uuid
string
volume
Property indicating the source volume.
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
volume_aggregate_pairs
Volume-aggregate pair information.
aggregate
aggregate
volume
volume
volume_placement
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET. Volume placement is ignored if the migration resumes from the cleanup_failed state.
aggregates
array[aggregates]
Optional property used to specify the list of desired aggregates to use for volume creation in the destination.
array[volume_aggregate_pairs]
Optional property used to specify the list of desired volume-aggregate pairs in the destination.
destination
Destination cluster details for the SVM migration.
ipspace
ipspace
ip
IP information
address
string
IPv4 or IPv6 address
interface
Network interface on the source SVM.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
node
name
string
Name of node on which the port is located.
port
Port to use for IP interface placement on the destination SVM.
_links
_links
name
string
node
node
uuid
string
ip_interfaces
IP interface and network port pair information.
interface
interface
port
port
svm_migration_ip_interface_placement
Optional property used to specify the list of source SVM's IP interface and network port pairs in the destination for migrating the source SVM IP interfaces. Note that the SVM migration does not perform any reachability checks on the IP interfaces provided.
ip_interfaces
array[ip_interfaces]
List of source SVM's IP interface and port pairs on the destination for migrating the source SVM's IP interfaces.
messages
code
string
Argument code
message
string
Message argument
cluster
Source cluster for the SVM migration.
_links
_links
name
string
uuid
string
svm
Source SVM
_links
_links
name
string
uuid
string
source
Source cluster details for the SVM migration.
cluster
cluster
svm
svm
Source SVM
time_metrics
Various time metrics details
string
Cutover end time
cutover_start_time
string
Cutover start time
string
Cutover trigger time
end_time
string
Migration end time
last_pause_time
string
Last migration pause time
string
Last post point of no return retry time
last_resume_time
string
Last migration resume time
start_time
string
Migration start time
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
auto_cutover
boolean
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
auto_source_cleanup
boolean
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
current_operation
string
destination
destination
last_failed_state
string
Indicates the state of the migration.
last_operation
string
messages
array[messages]
Errors and warnings returned/displayed during migration.
point_of_no_return
boolean
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted.
integer
Number of times the migration restarted after the point of no return.
restart_count
integer
Number of times migrate restarted the transfer, for example, rollback to transfer after starting the cutover.
source
source
state
string
throttle
integer
Optional property to specify a throttle value in KB/s for each individual volume transfer. Defaults to 0 if not set, which is interpreted as unlimited. The minimum throttle value is 4 KB/s, so if you specify a throttle value between 1 and 4, it will be treated as if you specified 4.
time_metrics
time_metrics
uuid
string
SVM migration UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
