REST API reference
Retrieve SVM peer permissions
Retrieves a list of SVM peer permissions to review and manage access control between storage virtual machines. This is useful for ensuring that the appropriate permissions are set for SVM interactions.
HTTP method and endpoint
GET /svm/peer-permissions
Introduced in
ONTAP 9.6
  • vserver peer permission show
The following examples show how to retrieve a collection of SVM peer permissions based on a query.
  1. Retrieves a list of SVM peer permissions of a specific local SVM
 GET "/api/svm/peer-permissions/?svm.name=VS1"
  1. Retrieves a list of SVM peer permissions of a specific cluster peer
 GET "/api/svm/peer-permissions/?cluster_peer.name=cluster2"
cluster_peer.uuid
string
query
False
Filter by cluster_peer.uuid
cluster_peer.name
string
query
False
Filter by cluster_peer.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
applications
string
query
False
Filter by applications
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_peer_permission]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "applications": [
        "snapmirror",
        "flexcache"
      "cluster_peer": {
        "name": "cluster2",
        "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error codes Description
26345574
Failed to find the SVM or volume name with UUID.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster_peer
Peer cluster details
_links
_links
name
string
uuid
string
svm
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".
_links
_links
name
string
The name of the SVM.
uuid
string
svm_peer_permission
Manage SVM peer permissions.
_links
_links
applications
array[string]
A list of applications for an SVM peer relation.
cluster_peer
cluster_peer
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
