Retrieve SVM peer permissions
Retrieves SVM peer permissions to view the list of permissions associated with storage virtual machine (SVM) peer relationships. This information helps you manage and verify access controls between SVM peers.
HTTP method and endpoint
GET /svm/peer-permissions
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of SVM peer permissions.
Related ONTAP commands
vserver peer permission show
The following examples show how to retrieve a collection of SVM peer permissions based on a query.
Retrieves a list of SVM peer permissions of a specific local SVM
GET "/api/svm/peer-permissions/?svm.name=VS1"
Retrieves a list of SVM peer permissions of a specific cluster peer
GET "/api/svm/peer-permissions/?cluster_peer.name=cluster2"
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
applications |
string |
query |
False |
Filter by applications |
cluster_peer.uuid |
string |
query |
False |
Filter by cluster_peer.uuid |
cluster_peer.name |
string |
query |
False |
Filter by cluster_peer.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_peer_permission] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"applications": [
"snapmirror",
"flexcache"
"cluster_peer": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345574 |
Failed to find the SVM or volume name with UUID. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster_peer
Peer cluster details
_links |
name |
string |
uuid |
string |
svm
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".
_links |
name |
string |
The name of the SVM. |
uuid |
string |
svm_peer_permission
Manage SVM peer permissions.
_links |
applications |
array[string] |
A list of applications for an SVM peer relation. |
cluster_peer |
Peer cluster details |
svm |
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*". |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
