REST API reference
Retrieve SVM peer permissions
Retrieves a list of SVM peer permissions to understand the access levels assigned for SVM interactions within your ONTAP system.
HTTP method and endpoint
GET /svm/peer-permissions
Introduced in
ONTAP 9.6
  • vserver peer permission show
The following examples show how to retrieve a collection of SVM peer permissions based on a query.
  1. Retrieves a list of SVM peer permissions of a specific local SVM
 GET "/api/svm/peer-permissions/?svm.name=VS1"
  1. Retrieves a list of SVM peer permissions of a specific cluster peer
 GET "/api/svm/peer-permissions/?cluster_peer.name=cluster2"
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
cluster_peer.name
string
query
False
Filter by cluster_peer.name
cluster_peer.uuid
string
query
False
Filter by cluster_peer.uuid
applications
string
query
False
Filter by applications
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[svm_peer_permission]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "applications": [
        "snapmirror",
        "flexcache"
      "cluster_peer": {
        "name": "cluster2",
        "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error codes Description
26345574
Failed to find the SVM or volume name with UUID.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster_peer
Peer cluster details
_links
_links
name
string
uuid
string
svm
Local SVM permitted for peer relationship. To create peer permissions for all SVMs, specify the SVM name as "*".
_links
_links
name
string
uuid
string
svm_peer_permission
Manage SVM peer permissions.
_links
_links
applications
array[string]
A list of applications for an SVM peer relationship.
cluster_peer
cluster_peer
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
