REST API reference
Manage event filter rules
Manage specific instances of rules within event filters to customize how events are processed and monitored in your system. Use these endpoints to retrieve, update, or delete rules based on specific criteria and ensure your event management aligns with operational requirements.
Overview
Manages a specific instance of a rule within a filter. See the documentation for /support/ems/filters for details on the various properties in a rule.
Retrieving a single instance of a rule
# The API:
GET /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "no-info-debug-events",
"index": 1,
"type": "include",
"message_criteria": {
  "name_pattern": "*",
  "severities": "emergency,alert,error,notice",
  "snmp_trap_types": "*",
      "href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
    "href": "/api/support/ems/filters/no-info-debug-events/rules/1"
Updating an existing rule to use severity emergency
# The API:
PATCH /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filter_rules_patch.txt"
test_ems_filter_rules_patch.txt(body):
  "severities": "emergency"
# The response:
200 OK
Deleting a rule from an existing filter
# The API:
DELETE /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
