REST API reference
Manage event filter rules
Manage specific instances of rules within event filters to control the types of messages and notifications you receive. Use these endpoints to retrieve, update, or delete rules based on your monitoring needs.
Overview
Manages a specific instance of a rule within a filter. See the documentation for /support/ems/filters for details on the various properties in a rule.
Retrieving a single instance of a rule
# The API:
GET /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "no-info-debug-events",
"index": 1,
"type": "include",
"message_criteria": {
  "name_pattern": "*",
  "severities": "emergency,alert,error,notice",
  "snmp_trap_types": "*",
      "href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
    "href": "/api/support/ems/filters/no-info-debug-events/rules/1"
Updating an existing rule to use severity emergency
# The API:
PATCH /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filter_rules_patch.txt"
test_ems_filter_rules_patch.txt(body):
  "severities": "emergency"
# The response:
200 OK
Deleting a rule from an existing filter
# The API:
DELETE /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
