Manage event filter rules
Use these endpoints to manage individual rules within event filters. You typically access these endpoints to retrieve, update, or delete specific rule instances based on your monitoring requirements.
Overview
Manages a specific instance of a rule within a filter. See the documentation for /support/ems/filters for details on the various properties in a rule.
Retrieving a single instance of a rule
# The API:
GET /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "no-info-debug-events",
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "*",
"severities": "emergency,alert,error,notice",
"snmp_trap_types": "*",
"href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
"parameter_criteria": [
"value_pattern": "*"
"href": "/api/support/ems/filters/no-info-debug-events/rules/1"
Updating an existing rule to use severity emergency
# The API:
PATCH /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filter_rules_patch.txt"
test_ems_filter_rules_patch.txt(body):
"severities": "emergency"
# The response:
200 OK
Deleting a rule from an existing filter
# The API:
DELETE /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
