REST API reference
Update a MetroCluster interconnect interface
Updates a MetroCluster interconnect interface to modify its configuration settings as needed. This operation is typically used to adjust interface parameters to ensure optimal MetroCluster functionality.
HTTP method and endpoint
PATCH /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
Introduced in
ONTAP 9.10
node.uuid
string
path
True
Node UUID
partner_type
string
path
True
DR Partner type
adapter
string
path
True
Interconnect adapter
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
adapter
string
Adapter
interfaces
array[interfaces]
List of objects which contain interface information such as its IP address, netmask and gateway.
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
vlan_id
integer
VLAN ID
Example request
  "adapter": "string",
  "interfaces": [
      "address": "10.10.10.7",
      "gateway": "10.1.1.1",
      "netmask": "24"
  "node": {
    "name": "node1",
  "partner_type": "string",
  "state": "string",
  "type": "string",
  "vlan_id": 0
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error has occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
string
interfaces
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
node
name
string
uuid
string
metrocluster_interconnect
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
adapter
string
Adapter
interfaces
array[interfaces]
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
vlan_id
integer
VLAN ID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
