REST API reference
Update a MetroCluster interconnect interface
Updates a MetroCluster interconnect interface to modify its settings or configuration, ensuring the interconnect operates as required for your MetroCluster environment.
HTTP method and endpoint
PATCH /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
Introduced in
ONTAP 9.10
node.uuid
string
path
True
Node UUID
partner_type
string
path
True
DR Partner type
adapter
string
path
True
Interconnect adapter
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
adapter
string
Adapter
interfaces
array[interfaces]
List of objects which contain interface information such as its IP address, netmask and gateway.
mirror
mirror
multipath_policy
string
Displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
vlan_id
integer
VLAN ID
Example request
  "adapter": "string",
  "interfaces": [
      "address": "10.10.10.7",
      "gateway": "10.1.1.1",
      "netmask": "24"
  "mirror": {
    "state": "string"
  "multipath_policy": "string",
  "node": {
    "name": "node1",
  "partner_type": "string",
  "state": "string",
  "type": "string",
  "vlan_id": 0
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error has occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2430347
The interface is already configured for port "adapter" with IP address "interfaces.address" on node "node.name". To configure a new IP address, run the "metrocluster configuration-settings interface delete" command to delete this interface and then run the "metrocluster configuration-settings interface create" command with the new IP address.
2430348
The interface is already configured for port "adapter" with gateway "interfaces.gateway" on node "node.name". To configure a new gateway or no gateway, run the "metrocluster configuration-settings interface delete" command to delete this interface and then run the "metrocluster configuration-settings interface create" command with the new gateway or no gateway.
2430352
The interface is already configured for port "adapter" with netmask "interfaces.netmask" on node "node.name". To configure a new netmask, run the "metrocluster configuration-settings interface delete" command to delete this interface and then run the "metrocluster configuration-settings interface create" command with the new netmask.
2430445
Configuration for the interface "port" on node "node.name" in cluster "cluster" does not exist. Use the "metrocluster configuration-settings interface show" command to list the valid interfaces configured for MetroCluster over IP.
2432885
Unable to modify the interface for adapter "port". Reason: At least one interface parameter is required to modify the interface.
string
interfaces
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
mirror
enabled
boolean
Specifies the administrative state of the NVRAM mirror between partner nodes.
state
string
Specifies the operational state of the NVRAM mirror between partner nodes.
node
name
string
uuid
string
metrocluster_interconnect
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
adapter
string
Adapter
interfaces
array[interfaces]
mirror
mirror
multipath_policy
string
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
vlan_id
integer
VLAN ID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
