Update a MetroCluster interconnect interface
PATCH /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
Introduced In: 9.10
Updates a MetroCluster interconnect interface.
Related ONTAP commands
metrocluster configuration-settings interface modify
node.uuid |
string |
path |
True |
Node UUID |
partner_type |
string |
path |
True |
DR Partner type |
adapter |
string |
path |
True |
Interconnect adapter |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
adapter |
string |
Adapter |
interfaces |
array[interfaces] |
List of objects which contain interface information such as its IP address, netmask and gateway. |
mirror |
multipath_policy |
string |
Displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster. |
node |
partner_type |
string |
Partner type |
state |
string |
Adapter status |
type |
string |
Adapter type |
vlan_id |
integer |
VLAN ID |
Example request
"adapter": "string",
"interfaces": [
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"mirror": {
"state": "string"
"multipath_policy": "string",
"node": {
"name": "node1",
"partner_type": "string",
"state": "string",
"type": "string",
"vlan_id": 0
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error has occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2430347 |
The interface is already configured for port "adapter" with IP address "interfaces.address" on node "node.name". To configure a new IP address, run the "metrocluster configuration-settings interface delete" command to delete this interface and then run the "metrocluster configuration-settings interface create" command with the new IP address. |
2430348 |
The interface is already configured for port "adapter" with gateway "interfaces.gateway" on node "node.name". To configure a new gateway or no gateway, run the "metrocluster configuration-settings interface delete" command to delete this interface and then run the "metrocluster configuration-settings interface create" command with the new gateway or no gateway. |
2430352 |
The interface is already configured for port "adapter" with netmask "interfaces.netmask" on node "node.name". To configure a new netmask, run the "metrocluster configuration-settings interface delete" command to delete this interface and then run the "metrocluster configuration-settings interface create" command with the new netmask. |
2430445 |
Configuration for the interface "port" on node "node.name" in cluster "cluster" does not exist. Use the "metrocluster configuration-settings interface show" command to list the valid interfaces configured for MetroCluster over IP. |
2432885 |
Unable to modify the interface for adapter "port". Reason: At least one interface parameter is required to modify the interface. |
href |
string |
self_link
interfaces
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
mirror
enabled |
boolean |
Specifies the administrative state of the NVRAM mirror between partner nodes. |
state |
string |
Specifies the operational state of the NVRAM mirror between partner nodes. |
_links
node
name |
string |
uuid |
string |
metrocluster_interconnect
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
adapter |
string |
Adapter |
interfaces |
array[interfaces] |
mirror |
multipath_policy |
string |
node |
partner_type |
string |
Partner type |
state |
string |
Adapter status |
type |
string |
Adapter type |
vlan_id |
integer |
VLAN ID |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
