Update the cluster software version
Updates the cluster software version to install a new software package on the cluster. Use this endpoint when you need to upgrade the cluster's software to a specified version.
HTTP method and endpoint
PATCH /cluster/software
Introduced in
ONTAP 9.6
Usage notes
Important note:
Setting 'version' triggers the package installation.
To validate the package for installation but not perform the installation, use the
validate_onlyfield on the request.
Required properties
version- Software version to be installed on the cluster.
Recommended optional parameters
validate_only- Required to validate a software package before an upgrade. -
skip_warnings- Used to skip validation warnings when starting a software upgrade. -
action- Used to pause, resume, or cancel an ongoing software upgrade. -
stabilize_minutes- Specifies a custom value between 1 to 60 minutes that allows each node a specified amount of time to stabilize after a reboot; the default is 8 minutes. -
estimate_only- Estimates the time duration; does not perform any update. -
nodes_to_update- Specifies a subset of the cluster's nodes for update.
Related ONTAP commands
cluster image validate -
cluster image update -
cluster image pause-update -
cluster image resume-update -
cluster image cancel-update
Learn more
skip_warnings |
boolean |
query |
False |
Ignore warnings and proceed with the install. |
action |
string |
query |
False |
Requests an upgrade to pause, resume, or cancel.
Note that not all upgrades support these actions. An upgrade can only be resumed if it is in the paused state. When a request to cancel an upgrade is successful, the upgrade state changes to either
stabilize_minutes |
integer |
query |
False |
Sets a custom value between 1 to 60 minutes for the upgrade, allowing each node a specified amount of time to stabilize after a reboot.
estimate_only |
boolean |
query |
False |
Generates an estimate of the time required for the overall update operation for the specified package. No update is performed when this option is used. The default is false.
force_rolling |
boolean |
query |
False |
Forces a rolling upgrade on the cluster. This option is not applicable for a single-node cluster and for a two-node MetroCluster. The default is false.
nodes_to_update |
string |
query |
False |
A comma separated list of node names to be updated. The nodes must be a part of a HA Pair. The default is all nodes.
pause_after |
string |
query |
False |
The pause after specified tasks option. When ANDU is paused user interaction is required to resume the update. The default is none.
return_timeout |
integer |
query |
False |
validate_only |
boolean |
query |
False |
Validate the operation and its parameters, without actually performing the operation. |
Request Body
| Name | Type | Description |
action |
string |
User triggered action to apply to the install operation |
elapsed_duration |
integer |
Elapsed time during the upgrade or validation operation |
estimated_duration |
integer |
Overall estimated time for completion of the upgrade or validation operation. |
metrocluster |
nodes |
array[software_node_reference] |
List of nodes, active versions, and firmware update progressions. |
pending_version |
string |
Version being installed on the system.
post_update_checks |
List of failed post-update checks' warnings, errors, and advice. |
state |
string |
Operational state of the upgrade |
status_details |
Display status details. |
update_details |
Display update progress details. |
validation_results |
List of validation warnings, errors, and advice. |
version |
string |
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
Example request
"action": "pause",
"elapsed_duration": 2140,
"estimated_duration": 5220,
"metrocluster": {
"clusters": [
"estimated_duration": 3480,
"name": "cluster_A",
"state": "in_progress"
"progress_details": {
"message": "Switchover in progress"
"progress_summary": {
"message": "MetroCluster updated successfully."
"nodes": [
"name": "node1",
"software_images": [
"package": "image.tgz"
"version": "ONTAP_X"
"pending_version": "ONTAP_X_1",
"post_update_checks": [
"action": {
"message": "Use NFS hard mounts, if possible."
"issue": {
"message": "Cluster HA is not configured in the cluster."
"status": "warning",
"update_check": "nfs_mounts"
"state": "completed",
"status_details": [
"action": {
"message": "string"
"end_time": "2019-02-02T19:00:00Z",
"issue": {
"code": 10551399,
"message": "Image update complete"
"name": "initialize",
"node": {
"name": "node1"
"start_time": "2019-02-02T19:00:00Z",
"state": "failed"
"update_details": [
"elapsed_duration": 2100,
"estimated_duration": 4620,
"node": {
"name": "node1"
"phase": "Post-update checks",
"state": "failed"
"validation_results": [
"action": {
"issue": {
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
software_mcc_reference
elapsed_duration |
integer |
Elapsed duration of update time (in seconds) of MetroCluster. |
integer |
Estimated duration of update time (in seconds) of MetroCluster. |
name |
string |
Name of the site in MetroCluster. |
state |
Upgrade state of MetroCluster. |
progress_details
message |
string |
MetroCluster update progress details. |
progress_summary
message |
string |
MetroCluster update progress summary. |
metrocluster
clusters |
array[software_mcc_reference] |
List of MetroCluster sites, statuses, and active ONTAP versions.
progress_details |
progress_summary |
job_link
uuid |
string |
worker_node
name |
string |
uuid |
string |
firmware_update_progress_state
attempts |
integer |
code |
integer |
Code corresponding to the status message. |
message |
string |
Error message returned when a cluster firmware update job fails. |
status |
string |
worker_node |
job |
update_states |
zip_file_name |
string |
firmware_disk
average_duration_per_disk |
integer |
Average firmware update duration per disk (in seconds). |
num_waiting_download |
integer |
The number of disks waiting to download the firmware update. |
total_completion_estimate |
integer |
Estimated firmware update duration to completion (in minutes). |
update_status |
Status of the background disk firmware update. |
firmware_dqp_record_count
alias |
integer |
Alias record count |
device |
integer |
Device record count |
drive |
integer |
Drive record count |
system |
integer |
System record count |
firmware_dqp
file_name |
string |
Firmware file name |
revision |
string |
Firmware revision |
version |
string |
Firmware version |
firmware_shelf
in_progress_count |
integer |
update_status |
Status of the shelf firmware update. |
firmware_sp_bmc
autoupdte |
boolean |
end_time |
string |
fw_type |
string |
image |
string |
in_progress |
boolean |
is_current |
boolean |
last_update_state |
string |
percent_done |
integer |
running_version |
string |
start_time |
string |
state |
string |
firmware
cluster_fw_progress |
array[firmware_update_progress] |
software_images
package |
string |
Package file name. |
name |
string |
Name of the node. |
software_images |
array[software_images] |
List of software image information. |
version |
string |
ONTAP version of the node.
action
message |
string |
Specifies the corrective action to take to resolve an error. |
issue
message |
string |
Details of the error or warning encountered by the update checks. |
software_validation_reference
action |
issue |
status |
string |
Status of the update check. |
update_check |
string |
Name of the update check. |
action
code |
integer |
Error code corresponding the status error |
message |
string |
Corrective action to be taken to resolve the status error. |
issue
code |
integer |
Error code corresponding to update status |
message |
string |
Update status details |
node
name |
string |
Name of the node to be retrieved for status details. |
software_status_details_reference
action |
end_time |
string |
End time for each status phase. |
issue |
name |
string |
Name of the phase to be retrieved for status details. |
node |
start_time |
string |
Start time for each status phase. |
state |
string |
Status of the phase |
node
name |
string |
Name of the node to be retrieved for update details. |
software_update_details_reference
elapsed_duration |
integer |
Elapsed duration for each update phase |
integer |
Estimated duration for each update phase |
node |
phase |
string |
Phase details |
state |
string |
State of the update phase |
software_reference
action |
string |
elapsed_duration |
integer |
integer |
metrocluster |
nodes |
pending_version |
string |
state |
string |
status_details |
update_details |
version |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
