REST API reference
Update the cluster software version
Updates the cluster software version to install the desired software package on the cluster. Use this endpoint when you need to manage software upgrades, including the ability to validate the package, pause or resume the upgrade, and customize node stabilization times.
HTTP method and endpoint
PATCH /cluster/software
Introduced in
ONTAP 9.6
Usage notes
Important note:
  • Setting 'version' triggers the package installation.
  • To validate the package for installation but not perform the installation, use the validate_only field on the request.
Required properties
  • version - Software version to be installed on the cluster.
  • validate_only - Required to validate a software package before an upgrade.
  • skip_warnings - Used to skip validation warnings when starting a software upgrade.
  • action - Used to pause, resume, or cancel an ongoing software upgrade.
  • stabilize_minutes - Specifies a custom value between 1 to 60 minutes that allows each node a specified amount of time to stabilize after a reboot; the default is 8 minutes.
  • estimate_only - Estimates the time duration; does not perform any update.
  • nodes_to_update - Specifies a subset of the cluster's nodes for update.
  • show_validation_details - If the value is set to true, then all validation details will be shown in the output.
  • cluster image validate
  • cluster image update
  • cluster image pause-update
  • cluster image resume-update
  • cluster image cancel-update
skip_warnings
boolean
query
False
Ignore warnings and proceed with the install.
action
string
query
False
Requests an upgrade to pause, resume, or cancel. Note that not all upgrades support these actions. An upgrade can only be resumed if it is in the paused state. When a request to cancel an upgrade is successful, the upgrade state changes to either success or failure.
  • enum: ["pause", "resume", "cancel"]
stabilize_minutes
integer
query
False
Sets a custom value between 1 to 60 minutes for the upgrade, allowing each node a specified amount of time to stabilize after a reboot.
  • Introduced in: 9.8
estimate_only
boolean
query
False
Generates an estimate of the time required for the overall update operation for the specified package. No update is performed when this option is used. The default is false.
  • Introduced in: 9.9
force_rolling
boolean
query
False
Forces a rolling upgrade on the cluster. This option is not applicable for a single-node cluster and for a two-node MetroCluster. The default is false.
nodes_to_update
string
query
False
A comma separated list of node names to be updated. The nodes must be a part of a HA Pair. The default is all nodes. If the nodes_to_update parameter is empty then upgrade will error out and will not proceed.
boolean
query
False
  • Introduced in: 9.11
pause_after
string
query
False
The pause after specified tasks option. When ANDU is paused user interaction is required to resume the update. The default is none.
  • enum: ["none", "takeover_giveback", "all"]
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
validate_only
boolean
query
False
Validate the operation and its parameters, without actually performing the operation.
Request Body
Name Type Description
action
string
User triggered action to apply to the install operation
elapsed_duration
integer
Elapsed time during the upgrade or validation operation
estimated_duration
integer
Overall estimated time for completion of the upgrade or validation operation.
metrocluster
metrocluster
nodes
array[software_node_reference]
List of nodes, active versions, and firmware update progressions.
pending_version
string
Version being installed on the system.
  • example: ONTAP_X_1
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
post_update_checks
array[software_validation_reference]
List of failed post-update checks' warnings, errors, and advice.
state
string
Operational state of the upgrade
status_details
array[software_status_details_reference]
Display status details.
update_details
array[software_update_details_reference]
Display update progress details.
validation_results
List of validation warnings, errors, and advice.
version
string
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
  • example: ONTAP_X
  • x-nullable: true
Example request
  "action": "pause",
  "elapsed_duration": 2140,
  "estimated_duration": 5220,
  "metrocluster": {
    "clusters": [
        "estimated_duration": 3480,
        "name": "cluster_A",
        "state": "in_progress"
    "progress_details": {
      "message": "Switchover in progress"
    "progress_summary": {
      "message": "MetroCluster updated successfully."
  "nodes": [
      "name": "node1",
      "software_images": [
          "package": "image.tgz"
      "version": "ONTAP_X"
  "pending_version": "ONTAP_X_1",
  "post_update_checks": [
      "action": {
        "message": "Use NFS hard mounts, if possible."
      "issue": {
        "message": "Cluster HA is not configured in the cluster."
      "status": "warning",
      "update_check": "nfs_mounts"
  "state": "completed",
  "status_details": [
      "action": {
        "message": "string"
      "end_time": "2019-02-02 14:00:00 -0500",
      "issue": {
        "code": 10551399,
        "message": "Image update complete"
      "name": "initialize",
      "node": {
        "name": "node1"
      "start_time": "2019-02-02 14:00:00 -0500",
      "state": "failed"
  "update_details": [
      "elapsed_duration": 2100,
      "estimated_duration": 4620,
      "node": {
        "name": "node1"
      "phase": "Post-update checks",
      "state": "failed"
  "validation_results": [
      "action": {
      "issue": {
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default, Error
string
software_mcc_reference
elapsed_duration
integer
Elapsed duration of update time (in seconds) of MetroCluster.
estimated_duration
integer
Estimated duration of update time (in seconds) of MetroCluster.
name
string
Name of the site in MetroCluster.
state
Upgrade state of MetroCluster.
progress_details
message
string
MetroCluster update progress details.
progress_summary
message
string
MetroCluster update progress summary.
metrocluster
clusters
array[software_mcc_reference]
List of MetroCluster sites, statuses, and active ONTAP versions.
  • readOnly: 1
progress_details
progress_details
progress_summary
progress_summary
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
worker_node
name
string
uuid
string
firmware_update_progress_state
attempts
integer
code
integer
Code corresponding to the status message.
message
string
Error message returned when a cluster firmware update job fails.
status
string
worker_node
worker_node
job
job_link
update_state
array[firmware_update_progress_state]
update_type
string
Specifies the type of update.
zip_file_name
string
firmware_disk
average_duration_per_disk
integer
Average firmware update duration per disk (in seconds).
num_waiting_download
integer
The number of disks waiting to download the firmware update.
total_completion_estimate
integer
Estimated firmware update duration to completion (in minutes).
update_status
Status of the background disk firmware update.
firmware_dqp_record_count
alias
integer
Alias record count
device
integer
Device record count
drive
integer
Drive record count
system
integer
System record count
firmware_dqp
file_name
string
Firmware file name
revision
string
Firmware revision
version
string
Firmware version
firmware_shelf
in_progress_count
integer
update_status
Status of the shelf firmware update.
firmware_sp_bmc
autoupdte
boolean
end_time
string
fw_type
string
string
in_progress
boolean
is_current
boolean
last_update_state
string
percent_done
integer
running_version
string
start_time
string
state
string
firmware
cluster_fw_progress
array[firmware_update_progress]
software_images
package
string
Package file name.
name
string
Name of the node.
software_images
array[software_images]
List of software image information.
version
string
ONTAP version of the node.
  • example: ONTAP_X
  • readOnly: 1
  • x-nullable: true
action
message
string
Specifies the corrective action to take to resolve an error.
issue
message
string
Details of the error or warning encountered by the update checks.
action
action
issue
issue
status
string
Status of the update check.
update_check
string
Name of the update check.
action
code
integer
Error code corresponding the status error
message
string
Corrective action to be taken to resolve the status error.
issue
code
integer
Error code corresponding to update status
message
string
Update status details
node
name
string
Name of the node to be retrieved for status details.
action
action
end_time
string
End time for each status phase.
issue
issue
name
string
Name of the phase to be retrieved for status details.
node
node
start_time
string
Start time for each status phase.
state
string
Status of the phase
node
name
string
Name of the node to be retrieved for update details.
elapsed_duration
integer
Elapsed duration for each update phase
estimated_duration
integer
Estimated duration for each update phase
node
node
phase
string
Phase details
state
string
State of the update phase
software_reference
action
string
elapsed_duration
integer
estimated_duration
integer
metrocluster
metrocluster
nodes
pending_version
string
  • readOnly: 1
  • x-nullable: true
post_update_checks
state
string
status_details
update_details
validation_results
version
string
  • example: ONTAP_X
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
