REST API reference
Update the cluster software version
Updates the cluster software version to install a new package and enhance system functionality. You might perform this operation to apply critical updates or new features to your cluster environment.
HTTP method and endpoint
PATCH /cluster/software
Introduced in
ONTAP 9.6
Usage notes
Important note:
  • Setting 'version' triggers the package installation.
  • To validate the package for installation but not perform the installation, use the validate_only field on the request.
Required properties
  • version - Software version to be installed on the cluster.
  • validate_only - Required to validate a software package before an upgrade.
  • skip_warnings - Used to skip validation warnings when starting a software upgrade.
  • action - Used to pause, resume, or cancel an ongoing software upgrade.
  • stabilize_minutes - Specifies a custom value between 1 to 60 minutes that allows each node a specified amount of time to stabilize after a reboot; the default is 8 minutes.
  • estimate_only - Estimates the time duration; does not perform any update.
  • nodes_to_update - Specifies a subset of the cluster's nodes for update.
  • show_validation_details - If the value is set to true, then all validation details will be shown in the output.
  • skip_nodes_at_target_version - If the value is set to true, then nodes already at the target version will not be upgraded. Defaults to true in non-MetroCluster configurations. Setting this option to false will force all the selected nodes of the cluster to undergo upgrade.
  • cluster image validate
  • cluster image update
  • cluster image pause-update
  • cluster image resume-update
  • cluster image cancel-update
skip_warnings
boolean
query
False
Ignore warnings and proceed with the install.
action
string
query
False
Requests an upgrade to pause, resume, or cancel. Note that not all upgrades support these actions. An upgrade can only be resumed if it is in the paused state. When a request to cancel an upgrade is successful, the upgrade state changes to either success or failure.
  • enum: ["pause", "resume", "cancel"]
stabilize_minutes
integer
query
False
Sets a custom value between 1 to 60 minutes for the upgrade, allowing each node a specified amount of time to stabilize after a reboot.
  • Introduced in: 9.8
estimate_only
boolean
query
False
Generates an estimate of the time required for the overall update operation for the specified package. No update is performed when this option is used. The default is false.
  • Introduced in: 9.9
force_rolling
boolean
query
False
Forces a rolling upgrade on the cluster. This option is not applicable for a single-node cluster and for a two-node MetroCluster. The default is false.
nodes_to_update
string
query
False
A comma separated list of node names to be updated. The nodes must be a part of a HA Pair. The default is all nodes. If the nodes_to_update parameter is empty then upgrade will error out and will not proceed.
boolean
query
False
  • Introduced in: 9.11
boolean
query
False
Defaults to true in non-MetroCluster configurations. When set to true, nodes already at the target version will not be upgraded. Setting this field to false will force nodes at the target version to undergo upgrade including migrating LIFs, performing takeover/giveback, and rebooting. It's invalid to set this option to true when the action field is set. It's an invalid option until effective cluster version is 9_16_0.
  • Introduced in: 9.16
pause_after
string
query
False
The pause after specified tasks option. When ANDU is paused user interaction is required to resume the update. The default is none.
  • enum: ["none", "takeover_giveback", "all"]
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
validate_only
boolean
query
False
Validate the operation and its parameters, without actually performing the operation.
Request Body
Name Type Description
action
string
User triggered action to apply to the install operation
elapsed_duration
integer
Elapsed time during the upgrade or validation operation
estimated_duration
integer
Overall estimated time for completion of the upgrade or validation operation.
metrocluster
metrocluster
nodes
array[software_node_reference]
List of nodes, active versions, and firmware update progressions.
pending_version
string
Version being installed on the system.
  • example: ONTAP_X_1
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
post_update_checks
array[software_validation_reference]
List of failed post-update checks' warnings, errors, and advice.
state
string
Operational state of the upgrade
status_details
array[software_status_details_reference]
Display status details.
update_details
array[software_update_details_reference]
Display update progress details.
validation_results
List of validation warnings, errors, and advice.
version
string
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
  • example: ONTAP_X
  • x-nullable: true
Example request
  "action": "pause",
  "elapsed_duration": 2140,
  "estimated_duration": 5220,
  "metrocluster": {
    "clusters": [
        "estimated_duration": 3480,
        "name": "cluster_A",
        "state": "in_progress"
    "progress_details": {
      "message": "Switchover in progress"
    "progress_summary": {
      "message": "MetroCluster updated successfully."
  "nodes": [
      "name": "node1",
      "software_images": [
          "package": "image.tgz"
      "version": "ONTAP_X"
  "pending_version": "ONTAP_X_1",
  "post_update_checks": [
      "action": {
        "message": "Use NFS hard mounts, if possible."
      "issue": {
        "message": "Cluster HA is not configured in the cluster."
      "status": "warning",
      "update_check": "nfs_mounts"
  "state": "completed",
  "status_details": [
      "action": {
        "message": "string"
      "end_time": "2019-02-02 14:00:00 -0500",
      "issue": {
        "code": 10551399,
        "message": "Image update complete"
      "name": "initialize",
      "node": {
        "name": "node1"
      "start_time": "2019-02-02 14:00:00 -0500",
      "state": "failed"
  "update_details": [
      "elapsed_duration": 2100,
      "estimated_duration": 4620,
      "node": {
        "name": "node1"
      "phase": "Post-update checks",
      "state": "failed"
  "validation_results": [
      "action": {
      "issue": {
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
2424933
An internal error occurred while checking MetroCluster information.
2424998
An internal error occurred while checking MetroCluster configuration.
2425737
10551297
Failed to find an update in progress.
10551298
Internal error while attempting to pause the upgrade operation.
10551300
There is no update in progress to be paused.
10551303
The operation is invalid while the update is not in the paused state.
10551304
An internal error occurred while canceling the current update operation.
10551306
A cancel operation is not possible at this time.
10551315
Failed to find the package in the package repository.
10551319
An internal error occurred while preparing for the update.
10551320
Failed to create task on master update manager node.
10551325
The required package version is not present in RDB.
10551353
Internal error occurred while running the ANDU pre-validation checks.
10551354
Invalid operation while the package is being deleted.
10551357
The operation is invalid while a previous update is still in progress.
10551368
The list of nodes should contain HA pairs only.
10551391
An internal error occurred while performing the upgrade operation.
10551395
ANDU validation check resulted in warnings.
10551396
ANDU validation checks failed.
10551434
The options are invalid for a resume operation.
10551524
The upgrade operation is in the running state, pause the operation before attempting to cancel.
10551558
Cluster configuration is not supported.
10551564
Batch mode upgrade is not supported for MetroCluster configurations.
10551565
Failed to contact the MetroCluster partner cluster, check the MetroCluster configuration then try again.
10551566
Validation is not complete on the partner MetroCluster cluster.
10551567
The required package is not available on the partner MetroCluster cluster.
10551572
Internal error while checking the update status from RDB. Ensure that cluster is healthy and retry the operation.
10551573
The running update is not in paused state on the MetroCluster partner cluster, so it cannot be resumed.
10551574
The running update is not in the paused state on the MetroCluster partner cluster, so it cannot be canceled.
10551592
The nodes selection option is not supported for MetroCluster configurations.
10551599
Double-hop package is missing.
10551602
A double-hop upgrade is not supported.
10551606
An option selected requires a higher effective cluster version.
10551643
Operation invalid while controller replacement is in progress.
10551656
Invalid operation while ANDU validation checks are in progress.
10551718
Invalid operation before running validation checks.
10551719
ANDU validation results are too old.
10551720
ANDU validation checks have failed with errors on both clusters in a MetroCluster config.
10551724
ANDU validation checks were run on a different version from the requested operation.
10551837
An internal error occurred while generating the AutoSupport prior to starting ANDU.
10551840
10551841
10551854
All specified nodes are already running the specified package version.
10551859
Failed to access the package repository and its backup copy.
10551897
All nodes are already running the requested version.
10551898
Failed to get nodes-to-update list.
10551899
skip_nodes_at_target_version cannot be specified in a validate_only, pause, resume, or cancel operations.
10551900
skip_nodes_at_target_version cannot be set to true in MetroCluster configurations.
10551901
skip_nodes_at_target_version conflicts with another specified field.
10551902
Failed to determine if the cluster is configured for MetroCluster.
10551908
skip_nodes_at_target_version is not a valid option until effective cluster version is 9_16_0.
10551910
The operation is invalid while in the current upgrade state.
13303864
SnapMirror operation is in progress, retry later.
string
software_mcc_reference
elapsed_duration
integer
Elapsed duration of update time (in seconds) of MetroCluster.
estimated_duration
integer
Estimated duration of update time (in seconds) of MetroCluster.
name
string
Name of the site in MetroCluster.
state
Upgrade state of MetroCluster.
progress_details
message
string
MetroCluster update progress details.
progress_summary
message
string
MetroCluster update progress summary.
metrocluster
clusters
array[software_mcc_reference]
List of MetroCluster sites, statuses, and active ONTAP versions.
  • readOnly: 1
progress_details
progress_details
progress_summary
progress_summary
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
worker_node
name
string
uuid
string
firmware_update_progress_state
attempts
integer
code
integer
Code corresponding to the status message.
message
string
Error message returned when a cluster firmware update job fails.
status
string
worker_node
worker_node
job
job_link
update_state
array[firmware_update_progress_state]
update_type
string
Specifies the type of update.
zip_file_name
string
firmware_disk
average_duration_per_disk
integer
Average firmware update duration per disk (in seconds).
num_waiting_download
integer
The number of disks waiting to download the firmware update.
total_completion_estimate
integer
Estimated firmware update duration to completion (in minutes).
update_status
Status of the background disk firmware update.
firmware_dqp_record_count
alias
integer
Alias record count
device
integer
Device record count
drive
integer
Drive record count
system
integer
System record count
firmware_dqp
file_name
string
Firmware file name
revision
string
Firmware revision
version
string
Firmware version
firmware_shelf
in_progress_count
integer
update_status
Status of the shelf firmware update.
firmware_sp_bmc
autoupdate
boolean
end_time
string
fw_type
string
string
in_progress
boolean
is_current
boolean
last_update_state
string
percent_done
integer
running_version
string
start_time
string
state
string
firmware
cluster_fw_progress
array[firmware_update_progress]
software_images
package
string
Package file name.
name
string
Name of the node.
software_images
array[software_images]
List of software image information.
version
string
ONTAP version of the node.
  • example: ONTAP_X
  • readOnly: 1
  • x-nullable: true
action
message
string
Specifies the corrective action to take to resolve an error.
issue
message
string
Details of the error or warning encountered by the update checks.
action
action
issue
issue
status
string
Status of the update check.
update_check
string
Name of the update check.
action
code
integer
Error code corresponding the status error
message
string
Corrective action to be taken to resolve the status error.
issue
code
integer
Error code corresponding to update status
message
string
Update status details
node
name
string
Name of the node to be retrieved for status details.
action
action
end_time
string
End time for each status phase.
issue
issue
name
string
Name of the phase to be retrieved for status details.
node
node
start_time
string
Start time for each status phase.
state
string
Status of the phase
node
name
string
Name of the node to be retrieved for update details.
elapsed_duration
integer
Elapsed duration for each update phase
estimated_duration
integer
Estimated duration for each update phase
node
node
phase
string
Phase details
state
string
State of the update phase
software_reference
action
string
elapsed_duration
integer
estimated_duration
integer
metrocluster
metrocluster
nodes
pending_version
string
  • readOnly: 1
  • x-nullable: true
post_update_checks
state
string
status_details
update_details
validation_results
version
string
  • example: ONTAP_X
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
