Update local group information for a group in an SVM
Updates the local group information for a specified group within an SVM, which includes the ability to rename the group. Use this when you need to modify group details or change its name in your SVM configuration.
HTTP method and endpoint
PATCH /protocols/cifs/local-groups/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Updates the local group information of the specified group in the specified SVM. This API can also be used to rename a local group.
Related ONTAP commands
vserver cifs users-and-groups local-group modify -
vserver cifs users-and-groups local-group rename
Learn more
sid |
string |
path |
True |
Local group SID |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
description |
string |
Description for the local group. |
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
svm |
Example request
"description": "This is a local group",
"name": "SMB_SERVER01\\group",
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655661 |
The group name and description should not exceed 256 characters. |
655668 |
The specified group name contains illegal characters. |
655675 |
The local domain name specified in the group name does not exist. |
655682 |
The group name cannot be blank. |
655712 |
To rename an existing group, the local domain specified in name must match the local domain of the group to be renamed. |
655713 |
Failed to rename a group. The error code returned details the failure along with the reason for the failure. Take corrective actions as per the specified reason. |
href |
string |
_links
members
svm
name |
string |
The name of the SVM. |
uuid |
string |
local_cifs_group
description |
string |
name |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
