Update local group information for a group in an SVM
PATCH /protocols/cifs/local-groups/{svm.uuid}/{sid}
Introduced In: 9.10
Updates the local group information of the specified group in the specified SVM. This API can also be used to rename a local group.
Related ONTAP commands
vserver cifs users-and-groups local-group modify -
vserver cifs users-and-groups local-group rename
Learn more
sid  |
string  |
path  |
True  |
Local group SID  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
description  |
string  |
Description for the local group.  |
members  |
array[members]  |
name  |
string  |
Local group name. The maximum supported length of a group name is 256 characters.  |
sid  |
string  |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
Example request
  "description": "This is a local group",
  "members": [
  "name": "SMB_SERVER01\\group",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655661  |
The group name and description should not exceed 256 characters.  |
655668  |
The specified group name contains illegal characters.  |
655675  |
The local domain name specified in the group name does not exist.  |
655682  |
The group name cannot be blank.  |
655712  |
To rename an existing group, the local domain specified in name must match the local domain of the group to be renamed.  |
655713  |
Failed to rename a group. The error code returned details the failure along with the reason for the failure. Take corrective actions as per the specified reason.  |
href  |
string  |
_links
members
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
local_cifs_group
description  |
string  |
members  |
array[members]  |
name  |
string  |
sid  |
string  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
