REST API reference
Update local group information for a group in an SVM
Updates the local group information for a specified group within an SVM, which includes the ability to rename the group. Use this when you need to modify group details or change its name in your SVM configuration.
HTTP method and endpoint
PATCH /protocols/cifs/local-groups/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Updates the local group information of the specified group in the specified SVM. This API can also be used to rename a local group.
  • vserver cifs users-and-groups local-group modify
  • vserver cifs users-and-groups local-group rename
sid
string
path
True
Local group SID
svm.uuid
string
path
True
Request Body
Name Type Description
description
string
Description for the local group.
members
array[members]
name
string
Local group name. The maximum supported length of a group name is 256 characters.
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
svm
svm
Example request
  "description": "This is a local group",
  "members": [
  "name": "SMB_SERVER01\\group",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655661
The group name and description should not exceed 256 characters.
655668
The specified group name contains illegal characters.
655675
The local domain name specified in the group name does not exist.
655682
The group name cannot be blank.
655712
To rename an existing group, the local domain specified in name must match the local domain of the group to be renamed.
655713
Failed to rename a group. The error code returned details the failure along with the reason for the failure. Take corrective actions as per the specified reason.
string
members
svm
name
string
uuid
string
local_cifs_group
description
string
members
array[members]
name
string
sid
string
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
