Update a primary key server
Updates a primary key server configuration, which is essential for managing secure key operations.
HTTP method and endpoint
PATCH /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
Usage notes
Updates a key server.
Related ONTAP commands
security key-manager external modify-server
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
path |
True |
Key server configured in the external key manager. |
Request Body
| Name | Type | Description |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
secondary_key_servers |
array[string] |
A list of the secondary key servers associated with the primary key server. |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
Example request
"password": "password",
"secondary_key_servers": [
"string"
"timeout": 60,
"username": "username"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536828 |
External key management is not enabled for the SVM. |
65536843 |
The key management server is not configured for the SVM. |
65536845 |
Missing username. |
65536846 |
Missing password. |
href |
string |
_links
records
password |
string |
array[string] |
timeout |
integer |
username |
string |
key_server
password |
string |
array[string] |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
