Update a primary key server
Updates a primary key server to modify its configuration settings as needed.
HTTP method and endpoint
PATCH /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
Related ONTAP commands
security key-manager external modify-server
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
path |
True |
Primary key server configured in the external key manager. |
Request Body
| Name | Type | Description |
create_remove_timeout |
integer |
The key server timeout for create and remove operations. -1 indicates that the server will wait indefinitely for the event to occur. 0 indicates that the server will not wait and will immediately timeout if it does not receive a response. |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
secondary_key_servers |
array[string] |
A list of the secondary key servers associated with the primary key server. |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. -1 indicates that the server will wait indefinitely for the event to occur. 0 indicates that the server will not wait and will immediately timeout if it does not receive a response. |
username |
string |
KMIP username credentials for connecting with the key server. |
Example request
"create_remove_timeout": 60,
"password": "password",
"secondary_key_servers": [
"secondary1.com",
"10.1.2.3"
"timeout": 60,
"username": "username"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536600 |
Cannot modify a key server while a node is out quorum. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536828 |
External key management is not enabled for the SVM. |
65536843 |
The key management server is not configured for the SVM. |
65536845 |
Missing username. |
65536846 |
Missing password. |
65536880 |
One or more of the following values must be provided "timeout", "username", "password", "secondary_key_servers", "create_remove_timeout". |
65536921 |
Unable to execute the command on the KMIP server. |
65537400 |
Exceeded maximum number of secondary key servers. |
65538407 |
A secondary key server is a duplicate of the associated primary key server. |
65538408 |
The list of secondary key servers contains duplicates. |
65538413 |
A secondary key server address is not formatted correctly. |
65538502 |
A secondary key server is also a primary key server. |
65538503 |
Support for adding secondary key servers requires an ECV of ONTAP 9.11.1 or later. |
href |
string |
_links
node
name |
string |
uuid |
string |
key_server_state
The connectivity state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This property contains the key server connectivity state of all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability |
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
node_states |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
password |
string |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
key_server
integer |
password |
string |
array[string] |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
