REST API reference
Update a primary key server
Updates a primary key server to change its configuration settings, ensuring the server aligns with your key management requirements.
HTTP method and endpoint
PATCH /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
  • security key-manager external modify-server
uuid
string
path
True
External key manager UUID
server
string
path
True
Primary key server configured in the external key manager.
Request Body
Name Type Description
create_remove_timeout
integer
The key server timeout for create and remove operations. -1 indicates that the server will wait indefinitely for the event to occur. 0 indicates that the server will not wait and will immediately timeout if it does not receive a response.
password
string
Password credentials for connecting with the key server. This is not audited.
secondary_key_servers
array[string]
A list of the secondary key servers associated with the primary key server.
timeout
integer
I/O timeout in seconds for communicating with the key server. -1 indicates that the server will wait indefinitely for the event to occur. 0 indicates that the server will not wait and will immediately timeout if it does not receive a response.
username
string
KMIP username credentials for connecting with the key server.
Example request
  "create_remove_timeout": 60,
  "password": "password",
  "secondary_key_servers": [
    "secondary1.com",
    "10.1.2.3"
  "timeout": 60,
  "username": "username"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536600
Cannot modify a key server while a node is out quorum.
65536824
Multitenant key management is not supported in MetroCluster configurations.
65536828
External key management is not enabled for the SVM.
65536843
The key management server is not configured for the SVM.
65536845
Missing username.
65536846
Missing password.
65536880
One or more of the following values must be provided "timeout", "username", "password", "secondary_key_servers", "create_remove_timeout".
65536921
Unable to execute the command on the KMIP server.
65537400
Exceeded maximum number of secondary key servers.
65538407
A secondary key server is a duplicate of the associated primary key server.
65538408
The list of secondary key servers contains duplicates.
65538413
A secondary key server address is not formatted correctly.
65538502
A secondary key server is also a primary key server.
65538503
Support for adding secondary key servers requires an ECV of ONTAP 9.11.1 or later.
string
node
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
records
password
string
timeout
integer
username
string
key_server
integer
password
string
array[string]
timeout
integer
username
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
