Cancel an ongoing SnapMirror transfer
Aborts an ongoing SnapMirror transfer to stop the data replication process between storage systems when immediate transfer cancellation is necessary.
HTTP method and endpoint
PATCH /snapmirror/relationships/{relationship.uuid}/transfers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
This operation is applicable on asynchronous SnapMirror relationships.
Related ONTAP commands
snapmirror abort
Example
PATCH "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers/293baa53-e63d-11e8-bff1-005056a793dd" '{"state":"aborted"}'
relationship.uuid |
string |
path |
True |
Relationship UUID |
uuid |
string |
path |
True |
Transfer UUID |
Request Body
| Name | Type | Description |
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
Amount of data transferred in bytes as recorded in the restart checkpoint. |
end_time |
string |
End time of the transfer. |
error_info |
Error information for the transfer. |
relationship |
snapshot |
string |
Name of Snapshot copy being transferred. |
state |
string |
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint. |
throttle |
integer |
Throttle in KB/s. Defaults to throttle setting of the associated SnapMirror policy if set, or 0, which is interpreted as unlimited. |
total_duration |
string |
Elapsed transfer time. |
uuid |
string |
Example request
"bytes_transferred": 0,
"checkpoint_size": 0,
"end_time": "2020-12-02T18:36:19-08:00",
"error_info": {
"code": 6620046,
"message": "Transfer aborted"
"relationship": {
"destination": {
"cluster": {
"name": "cluster1",
"consistency_group_volumes": [
"name": "volume1",
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
"snapshot": "string",
"state": "string",
"storage_efficiency_enabled": null,
"throttle": 0,
"total_duration": "PT28M41S",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303848 |
Abort of sync SnapMirror is not allowed |
13303849 |
SnapMirror transfer state is invalid |
href |
string |
_links
error_info
code |
integer |
Error code |
message |
string |
Error message |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path |
string |
source_path |
string |
cluster
name |
string |
uuid |
string |
name |
string |
The name of the volume. |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster |
consistency_group_volumes |
array[consistency_group_volumes] |
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group. |
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
svm |
relationship
destination |
restore |
boolean |
Is the relationship for restore? |
uuid |
string |
snapmirror_transfer
SnapMirror transfer information
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
end_time |
string |
error_info |
relationship |
snapshot |
string |
state |
string |
throttle |
integer |
total_duration |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
