Cancel an ongoing SnapMirror transfer
PATCH /snapmirror/relationships/{relationship.uuid}/transfers/{uuid}
Introduced In: 9.6
Aborts an ongoing SnapMirror transfer. This operation is applicable on asynchronous SnapMirror relationships.
Related ONTAP commands
snapmirror abort
Example
PATCH "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers/293baa53-e63d-11e8-bff1-005056a793dd" '{"state":"aborted"}'
Name | Type | In | Required | Description |
relationship.uuid |
string |
path |
True |
SnapMirror relationship UUID |
uuid |
string |
path |
True |
SnapMirror transfer UUID |
Request Body
Name | Type | Description |
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
Amount of data transferred in bytes as recorded in the restart checkpoint. |
end_time |
string |
End time of the transfer. |
error_info |
Error information for the transfer. |
last_updated_time |
string |
Last updated time of the bytes transferred in an active transfer. |
network_compression_ratio |
string |
Specifies the compression ratio achieved for the data sent over the wire with network compression enabled. This property is only valid for active transfers. |
on_demand_attrs |
string |
Specifies whether or not an on-demand restore is being carried out. This is only supported for the transfer of restore relationships for entire volumes from the object store. A value for read_write_with_user_data_pull should be provided to start an on-demand restore. A file restore from the object store does not support this option. |
relationship |
snapshot |
string |
Name of snapshot being transferred. |
state |
string |
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint. To find "queued" transfers refer to relationships GET API. |
total_duration |
string |
Elapsed transfer time. |
uuid |
string |
Unique identifier of the SnapMirror transfer. |
Example request
"bytes_transferred": 0,
"checkpoint_size": 0,
"end_time": "2020-12-02 21:36:19 -0500",
"error_info": {
"code": 6620046,
"message": "Transfer aborted"
"last_updated_time": "2023-09-15 19:58:39 -0400",
"network_compression_ratio": 61,
"on_demand_attrs": "read_write_with_user_data_pull",
"relationship": {
"destination": {
"cluster": {
"name": "cluster1",
"luns": {
"name": "/vol/volume1/lun1",
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
"snapshot": "string",
"state": "string",
"storage_efficiency_enabled": true,
"total_duration": "PT28M41S",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code | Description |
13303848 |
Abort of sync SnapMirror is not allowed |
13303849 |
SnapMirror transfer state is invalid |
href |
string |
_links
error_info
code |
integer |
Error code |
message |
string |
Error message |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path |
string |
source_path |
string |
options
cluster
name |
string |
uuid |
string |
consistency_group_volumes
name |
string |
The name of the volume. |
luns
Optional property for a SnapMirror endpoint. Specifies the list of source LUNs and optionally list of destination LUNs during SnapMirror Consistency Group LUN restore operation.
name |
string |
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the LUN. |
svm
name |
string |
uuid |
string |
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster |
luns |
Optional property for a SnapMirror endpoint. Specifies the list of source LUNs and optionally list of destination LUNs during SnapMirror Consistency Group LUN restore operation. |
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
svm |
relationship
destination |
restore |
boolean |
Is the relationship for restore? |
uuid |
string |
Unique identifier of the SnapMirror relationship. |
snapmirror_transfer
SnapMirror transfer information
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
end_time |
string |
error_info |
last_updated_time |
string |
string |
on_demand_attrs |
string |
relationship |
snapshot |
string |
state |
string |
total_duration |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
