Update actions performed during an SVM migration
Updates the actions available for an SVM migration to manage and control the migration process effectively.
HTTP method and endpoint
PATCH /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Actions that can be performed during an SVM migration.
Related ONTAP commands
vserver migrate pause -
vserver migrate resume -
vserver migrate cutover -
vserver migrate source-cleanup
uuid |
string |
path |
True |
SVM migration UUID |
action |
string |
query |
False |
The pause action pauses the SVM migration. This action stops data transfer and configuration replication. This operation must be performed on the destination cluster. The resume action resumes an SVM migration from a paused or failed state. This operation must be performed on the destination cluster. The cutover action triggers the cutover of an SVM from the source cluster to the destination cluster. The source_clean up action performs a clean up of the SVM on the source cluster.
auto_cutover |
boolean |
query |
False |
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
auto_source_cleanup |
boolean |
query |
False |
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
