REST API reference
Update actions performed during an SVM migration
Updates the actions you can perform during an SVM migration to manage and control the migration process effectively.
HTTP method and endpoint
PATCH /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Actions that can be performed during an SVM migration.
  • vserver migrate pause
  • vserver migrate resume
  • vserver migrate cutover
  • vserver migrate source-cleanup
uuid
string
path
True
SVM migration UUID
action
string
query
False
The pause action pauses the SVM migration. This action stops data transfer and configuration replication. This operation must be performed on the destination cluster. The resume action resumes an SVM migration from a paused or failed state. This operation must be performed on the destination cluster. The cutover action triggers the cutover of an SVM from the source cluster to the destination cluster. The source_clean up action performs a clean up of the SVM on the source cluster.
  • enum: ["pause", "resume", "cutover", "source_cleanup"]
auto_cutover
boolean
query
False
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
  • Default value: 1
auto_source_cleanup
boolean
query
False
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
current_operation
string
destination
destination
Destination cluster details for the SVM migration.
last_failed_state
string
Indicates the state of the migration.
last_operation
string
messages
array[messages]
Errors and warnings returned/displayed during migration.
point_of_no_return
boolean
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted.
restart_count
integer
Number of times SVM migration was restarted since initially started.
source
source
Source cluster details for the SVM migration.
state
string
time_metrics
time_metrics
Various time metrics details
uuid
string
SVM migration UUID
Example request
  "auto_cutover": null,
  "auto_source_cleanup": null,
  "check_only": null,
  "current_operation": "string",
  "destination": {
    "volume_placement": {
      "volume_aggregate_pairs": [
          "aggregate": {
            "name": "aggr1",
          "volume": {
            "name": "volume1",
  "last_failed_state": "string",
  "last_operation": "string",
  "messages": [
      "message": "string"
  "restart_count": 0,
  "state": "string",
  "time_metrics": {
    "cutover_complete_time": "2020-12-02T19:30:19-08:00",
    "cutover_start_time": "2020-12-02T18:20:19-08:00",
    "cutover_trigger_time": "2020-12-02T19:15:19-08:00",
    "end_time": "2020-12-02T19:36:19-08:00",
    "last_pause_time": "2020-12-02T18:50:19-08:00",
    "last_resume_time": "2020-12-02T18:54:19-08:00",
    "start_time": "2020-12-02T18:36:19-08:00"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
string
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
name
string
IPspace name
uuid
string
IPspace UUID
aggregates
_links
_links
name
string
uuid
string
aggregate
Aggregate to use for volume creation.
name
string
uuid
string
volume
Property indicating the source volume.
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
Volume-aggregate pair information.
aggregate
aggregate
volume
volume
volume_placement
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET.
array[volume_aggregate_pairs]
Optional property used to specify the list of desired volume-aggregate pairs in the destination.
destination
volume_placement
volume_placement
ip
IP information
interface
Network interface on the source SVM.
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
node
name
string
Name of node on which the port is located.
port
Port to use for IP interface placement on the destination SVM.
name
string
node
node
uuid
string
ip_interfaces
IP interface and network port pair information.
interface
interface
port
port
svm_migration_ip_interface_placement
Optional property used to specify the list of source SVM's IP interface and network port pairs in the destination for migrating the source SVM IP interfaces. Note that the SVM migration does not perform any reachability checks on the IP interfaces provided.
ip_interfaces
array[ip_interfaces]
List of source SVM's IP interface and port pairs on the destination for migrating the source SVM's IP interfaces.
messages
Specifies failure codes and messages.
code
integer
Message code
message
string
Detailed message of warning or error.
cluster
Source cluster for the SVM migration.
name
string
uuid
string
svm
Source SVM
name
string
The name of the SVM.
uuid
string
source
time_metrics
string
Cutover end time
cutover_start_time
string
Cutover start time
string
Cutover trigger time
end_time
string
Migration end time
last_pause_time
string
Last migration pause time
last_resume_time
string
Last migration resume time
start_time
string
Migration start time
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
current_operation
string
destination
destination
last_failed_state
string
last_operation
string
messages
array[messages]
point_of_no_return
boolean
restart_count
integer
source
source
state
string
time_metrics
time_metrics
uuid
string
SVM migration UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
