Update actions performed during an SVM migration
Updates the actions performed during an SVM migration to manage and control the migration process.
HTTP method and endpoint
PATCH /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Actions that can be performed during an SVM migration.
Related ONTAP commands
vserver migrate pause -
vserver migrate resume -
vserver migrate cutover -
vserver migrate source-cleanup
uuid |
string |
path |
True |
SVM migration UUID |
action |
string |
query |
False |
The pause action pauses the SVM migration. This action stops data transfer and configuration replication. This operation must be performed on the destination cluster. The resume action resumes an SVM migration from a paused or failed state. If the SVM migration is in a cleanup_failed state, volume placement is ignored. This operation must be performed on the destination cluster. The cutover action triggers the cutover of an SVM from the source cluster to the destination cluster. The source_clean up action performs a clean up of the SVM on the source cluster.
auto_cutover |
boolean |
query |
False |
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
auto_source_cleanup |
boolean |
query |
False |
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
current_operation |
string |
destination |
Destination cluster details for the SVM migration. |
last_failed_state |
string |
Indicates the state of the migration. |
last_operation |
string |
messages |
array[messages] |
Errors and warnings returned/displayed during migration. |
point_of_no_return |
boolean |
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted. |
restart_count |
integer |
Number of times migrate restarted the transfer, for example, rollback to transfer after starting the cutover. |
source |
Source cluster details for the SVM migration. |
state |
string |
throttle |
integer |
Optional property to specify a throttle value in KB/s for each individual volume transfer. Defaults to 0 if not set, which is interpreted as unlimited. The minimum throttle value is 4 KB/s, so if you specify a throttle value between 1 and 4, it will be treated as if you specified 4. |
time_metrics |
Various time metrics details |
uuid |
string |
Example request
"auto_cutover": true,
"auto_source_cleanup": true,
"check_only": true,
"current_operation": "string",
"destination": {
"volume_placement": {
"volume_aggregate_pairs": [
"aggregate": {
"name": "aggr1",
"volume": {
"name": "volume1",
"last_failed_state": "string",
"last_operation": "string",
"messages": [
"code": "string",
"message": "string"
"restart_count": 0,
"state": "string",
"throttle": 0,
"time_metrics": {
"cutover_complete_time": "2020-12-02 22:30:19 -0500",
"cutover_start_time": "2020-12-02 21:20:19 -0500",
"cutover_trigger_time": "2020-12-02 22:15:19 -0500",
"end_time": "2020-12-02 22:36:19 -0500",
"last_pause_time": "2020-12-02 21:50:19 -0500",
"last_resume_time": "2020-12-02 21:54:19 -0500",
"start_time": "2020-12-02 21:36:19 -0500"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
13173737 |
REST API PATCH method \"/api/svm/migrations\" is only supported on the destination cluster. Issue the REST API PATCH request to the destination cluster. |
13173746 |
Migrate resume operation failed. Cannot specify volume granular placement during resume if aggregate placement was specified during start operation. |
13173747 |
Migrate operation failed. Volume placement can only be specified on PATCH with an action of \"resume\". |
13173748 |
Migrate request cannot contain both \"aggregates\" and \"volume_aggregate_pairs\" within the \"volume_placement\" object. |
13173763 |
Migrate operation failed. LIF placement is not supported in PATCH operations. |
href |
string |
_links
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
aggregates
Aggregate
name |
string |
uuid |
string |
aggregate
Aggregate to use for volume creation.
name |
string |
uuid |
string |
volume
Property indicating the source volume.
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
Volume-aggregate pair information.
aggregate |
Aggregate to use for volume creation. |
volume |
Property indicating the source volume. |
volume_placement
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET. Volume placement is ignored if the migration resumes from the cleanup_failed state.
volume_aggregate_pairs |
array[volume_aggregate_pairs] |
Optional property used to specify the list of desired volume-aggregate pairs in the destination. |
destination
volume_placement |
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET. Volume placement is ignored if the migration resumes from the cleanup_failed state. |
ip
IP information
interface
Network interface on the source SVM.
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
name |
string |
Name of node on which the port is located. |
port
Port to use for IP interface placement on the destination SVM.
name |
string |
node |
uuid |
string |
ip_interfaces
IP interface and network port pair information.
interface |
Network interface on the source SVM. |
port |
Port to use for IP interface placement on the destination SVM. |
svm_migration_ip_interface_placement
Optional property used to specify the list of source SVM's IP interface and network port pairs in the destination for migrating the source SVM IP interfaces. Note that the SVM migration does not perform any reachability checks on the IP interfaces provided.
ip_interfaces |
array[ip_interfaces] |
List of source SVM's IP interface and port pairs on the destination for migrating the source SVM's IP interfaces. |
messages
code |
string |
Argument code |
message |
string |
Message argument |
cluster
Source cluster for the SVM migration.
name |
string |
uuid |
string |
svm
Source SVM
name |
string |
uuid |
string |
source
time_metrics
cutover_complete_time |
string |
Cutover end time |
cutover_start_time |
string |
Cutover start time |
cutover_trigger_time |
string |
Cutover trigger time |
end_time |
string |
Migration end time |
last_pause_time |
string |
Last migration pause time |
last_resume_time |
string |
Last migration resume time |
start_time |
string |
Migration start time |
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
current_operation |
string |
destination |
last_failed_state |
string |
last_operation |
string |
messages |
array[messages] |
boolean |
restart_count |
integer |
source |
state |
string |
throttle |
integer |
time_metrics |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
