REST API reference
Restore an application component Snapshot copy
Restores a Snapshot copy of an application component to revert the application to a previous state. Use this when managing Maxdata template applications for more granular recovery needs.
HTTP method and endpoint
POST /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}/restore
Introduced in
ONTAP 9.6
Usage notes
Restore a Snapshot copy of an application component.
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
application.uuid
string
path
True
Application UUID
component.uuid
string
path
True
Application Component UUID
uuid
string
path
True
Snapshot copy UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
