Restore an application component Snapshot copy
Restores a Snapshot copy of an application component to revert the component to a previous state. Use this operation for granular recovery within Maxdata template applications.
HTTP method and endpoint
POST /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}/restore
Introduced in
ONTAP 9.6
Usage notes
Restore a Snapshot copy of an application component.
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
uuid |
string |
path |
True |
Snapshot copy UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
