Restore an application component snapshot
Restores a snapshot of an application component to revert it to a previous state. This operation is useful when you need to recover a component of a Maxdata template application to an earlier configuration.
HTTP method and endpoint
POST /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}/restore
Introduced in
ONTAP 9.6
Usage notes
Restore a snapshot of an application component.
This endpoint is only supported for Maxdata template applications.
Component snapshots are essentially more granular application snapshots. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
uuid |
string |
path |
True |
Snapshot UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default, Error
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
