REST API reference
Create an NTP symmetric authentication key entry
Creates an NTP symmetric authentication key entry to define a shared private key for secure Network Time Protocol communication. Use this when you need to configure time synchronization with enhanced security.
HTTP method and endpoint
POST /cluster/ntp/keys
Introduced in
ONTAP 9.7
Usage notes
Creates an NTP symmetric authentication key entry including the type of key using an unused identifier or index number (ID).
Required properties
  • id - Shared symmetric key number (ID).
  • digest_type - Shared private key cryptographic hash type.
  • value - Value of shared private key.
  • cluster time-service ntp key create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
digest_type
string
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header.
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID is included in the NTP cryptographic hash encoded header.
value
string
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters.
Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data.
Example request
  "digest_type": "sha1",
  "id": 10,
  "value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
2097187
Invalid value for an NTP symmetric authentication key. A SHA1 key must be exactly 40 hexadecimal digits.
2097189
Too many NTP keys have been configured.
string
ntp_key
digest_type
string
id
integer
value
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
