Create an NTP symmetric authentication key entry
Creates a symmetric authentication key entry for NTP, specifying the key type and using an unused identifier or index number. You typically perform this action to configure secure time synchronization within your network environment.
HTTP method and endpoint
POST /cluster/ntp/keys
Introduced in
ONTAP 9.7
Usage notes
Creates an NTP symmetric authentication key entry including the type of key using an unused identifier or index number (ID).
Required properties
id- Shared symmetric key number (ID). -
digest_type- Shared private key cryptographic hash type. -
value- Value of shared private key.
Related ONTAP commands
cluster time-service ntp key create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
digest_type |
string |
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header. |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID is included in the NTP cryptographic hash encoded header. |
value |
string |
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters. Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data. |
Example request
"digest_type": "sha1",
"id": 10,
"value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097187 |
Invalid value for an NTP symmetric authentication key. A SHA1 key must be exactly 40 hexadecimal digits. |
2097189 |
Too many NTP keys have been configured. |
href |
string |
_links
ntp_key
digest_type |
string |
id |
integer |
value |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
