Create an FC WWPN alias
Creates a Fibre Channel (FC) World Wide Port Name (WWPN) alias to associate a user-friendly name with a specific WWPN in your storage network. Use this to simplify management and identification of WWPNs within your storage environment.
HTTP method and endpoint
POST /network/fc/wwpn-aliases
Introduced in
ONTAP 9.6
Usage notes
Creates an FC WWPN alias.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the FC alias. -
alias- Name of the FC alias. -
wwpn- FC WWPN for which to create the alias.
Related ONTAP commands
vserver fcp wwpn-alias set
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
alias |
string |
The FC WWPN alias. Required in POST. |
svm |
wwpn |
string |
The FC initiator WWPN. Required in POST. |
Example request
"alias": "host1",
"svm": {
"name": "svm1",
"wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[wwpn_alias] |
"records": [
"alias": "host1",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254317 |
The alias already exists. |
1260882 |
The supplied SVM does not exist. |
2621462 |
2621706 |
Both the SVM UUID and SVM name were supplied, but do not refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5373982 |
An invalid WWPN was supplied. The valid WWN format is XX:XX:XX:XX:XX:XX:XX:XX, where X is a hexadecimal digit. Example: "01:02:03:04:0a:0b:0c:0d". |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
alias |
string |
svm |
wwpn |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
