Create an FC WWPN alias
POST /network/fc/wwpn-aliases
Introduced In: 9.6
Creates an FC WWPN alias.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the FC alias. -
alias- Name of the FC alias. -
wwpn- FC WWPN for which to create the alias.
Related ONTAP commands
vserver fcp wwpn-alias set
Learn more
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
alias  |
string  |
The FC WWPN alias. Required in POST.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
wwpn  |
string  |
The FC initiator WWPN. Required in POST.  |
Example request
  "alias": "host1",
  "svm": {
    "name": "svm1",
  "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: 201, Created
num_records  |
integer  |
The number of records in the response.  |
records  |
array[wwpn_alias]  |
  "num_records": 1,
  "records": [
      "alias": "host1",
      "svm": {
        "name": "svm1",
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462  |
The specified SVM does not exist or cannot be accessed by this user.  |
2621706  |
The specified   |
2621707  |
No SVM was specified. Either   |
5373982  |
An invalid WWN was specified. The length is incorrect.  |
5373983  |
An invalid WWN was specified. The format is incorrect.  |
5374869  |
The alias already exists.  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
alias  |
string  |
svm  |
wwpn  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
