REST API reference
Creates an fc wwpn alias
  • alias - name of the fc alias
  • wwpn - fc wwpn for which to create the alias # related ontap commands
  • vserver fcp wwpn-alias set # learn more
  • [doc /network/fc/wwpn-aliases](#docs-san-network_fc_wwpn-aliases)
POST /network/fc/wwpn-aliases
Creates an FC WWPN alias.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the FC alias.
  • alias - Name of the FC alias.
  • wwpn - FC WWPN for which to create the alias.
Request Body
Name Type Description
_links
_links
alias
string
The FC WWPN alias. Required in POST.
svm
svm
wwpn
string
The FC initiator WWPN. Required in POST.
Example request
      "href": "/api/resourcelink"
  "alias": "host1",
  "svm": {
    "name": "svm1",
  "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: 201, Created
_links
_links
num_records
integer
Number of records.
records
array[wwpn_alias]
    "next": {
  "records": [
      "alias": "host1",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
1254317
The alias already exists.
1260882
The supplied SVM does not exist.
2621462
2621706
Both the SVM UUID and SVM name were supplied, but don't refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373982
An invalid WWPN was supplied. The valid WWN format is XX:XX:XX:XX:XX:XX:XX:XX, where X is a hexadecimal digit. Example: "01:02:03:04:0a:0b:0c:0d".
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
_links
_links
alias
string
svm
svm
wwpn
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
