Create an FC WWPN alias
POST /network/fc/wwpn-aliases
Introduced In: 9.6
Creates an FC WWPN alias.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the FC alias. -
alias- Name of the FC alias. -
wwpn- FC WWPN for which to create the alias.
Related ONTAP commands
vserver fcp wwpn-alias set
Learn more
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
alias  |
string  |
The FC WWPN alias. Required in POST.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
wwpn  |
string  |
The FC initiator WWPN. Required in POST.  |
Example request
  "alias": "host1",
  "svm": {
    "name": "svm1",
  "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: 201, Created
num_records  |
integer  |
Number of records.  |
records  |
array[wwpn_alias]  |
  "records": [
      "alias": "host1",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254317  |
The alias already exists.  |
1260882  |
The supplied SVM does not exist.  |
2621462  |
2621706  |
Both the SVM UUID and SVM name were supplied, but do not refer to the same SVM.  |
2621707  |
No SVM was specified. Either   |
5373982  |
An invalid WWPN was supplied. The valid WWN format is XX:XX:XX:XX:XX:XX:XX:XX, where X is a hexadecimal digit. Example: "01:02:03:04:0a:0b:0c:0d".  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
alias  |
string  |
svm  |
wwpn  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
