REST API reference
Create an FC WWPN alias
POST /network/fc/wwpn-aliases
Introduced In: 9.6
Creates an FC WWPN alias.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the FC alias.
  • alias - Name of the FC alias.
  • wwpn - FC WWPN for which to create the alias.
  • vserver fcp wwpn-alias set
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
alias
string
The FC WWPN alias. Required in POST.
svm
svm
wwpn
string
The FC initiator WWPN. Required in POST.
Example request
  "alias": "host1",
  "svm": {
    "name": "svm1",
  "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[wwpn_alias]
  "num_records": 1,
  "records": [
      "alias": "host1",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The specified SVM does not exist or cannot be accessed by this user.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373982
An invalid WWN was specified. The length is incorrect.
5373983
An invalid WWN was specified. The format is incorrect.
5374869
The alias already exists.
string
svm
name
string
uuid
string
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
alias
string
svm
svm
wwpn
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
