REST API reference
Creates a new domain within which ip addresses are unique svms, ports, and networks are scoped to a single ipspace
  • network ipspace create
POST /network/ipspaces
Introduced In: 9.6
Creates a new domain within which IP addresses are unique. SVMs, ports, and networks are scoped to a single IPspace.
Required properties
  • name - Name of the IPspace to create.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
IPspace name
uuid
string
The UUID that uniquely identifies the IPspace.
Example request
  "name": "ipspace1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1966586
The specified IPspace name is invalid because it is already used by a peered SVM.
1967102
A POST operation might have left the configuration in an inconsistent state. Check the configuration.
9240591
The name is not valid. The name is already in use by a cluster node, Vserver, or it is the name of the local cluster.
string
ipspace
name
string
IPspace name
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
