REST API reference
Create a new domain with unique IP addresses
Creates a new domain where IP addresses are unique, ensuring that SVMs, ports, and networks are scoped to a single IPspace. This is useful for isolating network resources within a distinct domain.
HTTP method and endpoint
POST /network/ipspaces
Introduced in
ONTAP 9.6
Usage notes
Creates a new domain within which IP addresses are unique. SVMs, ports, and networks are scoped to a single IPspace.
Required properties
  • name - Name of the IPspace to create.
  • network ipspace create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
IPspace name
uuid
string
The UUID that uniquely identifies the IPspace.
Example request
  "name": "ipspace1",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1377261
An IPspace with the same name already exists.
1966449
Invalid IPspace name in MetroCluster configurations.
1966586
The specified IPspace name is invalid because it is already used by a peered SVM.
1967102
A POST operation might have left the configuration in an inconsistent state. Check the configuration.
1969181
The "tcp_stack" field cannot be specified when creating an IPspace. Use the PATCH method to modify the TCP stack after the IPspace is created.
9240587
Name cannot be empty.
9240588
The name is too long.
9240589
Invalid character in name.
9240590
The name is reserved by the system.
9240591
The name is not valid. The name is already in use by a cluster node, Vserver, or it is the name of the local cluster.
53281576
Cannot create IPspace because the maximum number of custom IPspaces has already been reached on the cluster.
string
ipspace
name
string
IPspace name
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
