Create a new domain with unique IP addresses
POST /network/ipspaces
Introduced In: 9.6
Creates a new domain within which IP addresses are unique. SVMs, ports, and networks are scoped to a single IPspace.
Required properties
name- Name of the IPspace to create.
Related ONTAP commands
network ipspace create
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
name  |
string  |
IPspace name  |
uuid  |
string  |
The UUID that uniquely identifies the IPspace.  |
Example request
  "name": "ipspace1",
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1377261  |
An IPspace with the same name already exists.  |
1966449  |
Invalid IPspace name in MetroCluster configurations.  |
1966586  |
The specified IPspace name is invalid because it is already used by a peered SVM.  |
1967102  |
A POST operation might have left the configuration in an inconsistent state. Check the configuration.  |
9240587  |
Name cannot be empty.  |
9240588  |
The name is too long.  |
9240589  |
Invalid character in name.  |
9240590  |
The name is reserved by the system.  |
9240591  |
The name is not valid. The name is already in use by a cluster node, Vserver, or it is the name of the local cluster.  |
53281576  |
Cannot create IPspace because the maximum number of custom IPspaces has already been reached on the cluster.  |
href  |
string  |
_links
ipspace
name  |
string  |
IPspace name  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
