Create a new domain with unique IP addresses
POST /network/ipspaces
Creates a new domain within which IP addresses are unique. SVMs, ports, and networks are scoped to a single IPspace.
Required properties
name- Name of the IPspace to create.
Related ONTAP commands
network ipspace create
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
name |
string |
IPspace name |
uuid |
string |
The UUID that uniquely identifies the IPspace. |
Example request
"href": "/api/resourcelink"
"name": "ipspace1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967102 |
A POST operation might have left the configuration in an inconsistent state. Check the configuration. |
9240591 |
The name is not valid. The name is already in use by a cluster node, Vserver, or it is the name of the local cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
