REST API reference
Create a local group configuration for an SVM
Creates a local group configuration for a specified SVM, establishing the necessary group settings within the storage virtual machine environment. This is typically done to manage access and permissions for storage resources in ONTAP.
HTTP method and endpoint
POST /protocols/cifs/local-groups
Introduced in
ONTAP 9.9
Important notes
  • The group name can contain up to 256 characters.
  • The group name cannot be terminated by a period.
  • The group name does not support any of the following characters: " / ? [ ] , : \| < > + = ; ? * @ or ASCII characters in the range 1-31.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the local group.
  • name - Name of the local group.
  • vserver cifs users-and-groups local-group create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
description
string
Description for the local group.
name
string
Local group name. The maximum supported length of a group name is 256 characters.
svm
svm
Example request
  "description": "This is a local group",
  "name": "SMB_SERVER01\\group",
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
262278
Name is a required field.
655399
CIFS server must exist to create a local group.
655660
The operation is allowed only on data SVMs.
655661
The group name and description should not exceed 256 characters.
655668
The specified group name contains illegal characters.
655675
The local domain name specified in the group name does not exist.
655677
This operation does not allow for the creation of a group in the BUILTIN domain.
655682
The group name cannot be blank.
655717
The specified group name already exists.
2621706
The specified SVM UUID is incorrect for the specified SVM name.
string
members
name
string
Local user, Active Directory user, or Active Directory group which is a member of the specified local group.
svm
name
string
The name of the SVM.
uuid
string
local_cifs_group
description
string
name
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
