Create the local group configuration for an SVM
Configures a local group for a specific SVM, defining group settings within the ONTAP environment. This is useful for managing access and permissions associated with the SVM.
HTTP method and endpoint
POST /protocols/cifs/local-groups
Introduced in
ONTAP 9.9
Usage notes
Creates the local group configuration for the specified SVM.
Important notes
The group name can contain up to 256 characters.
The group name cannot be terminated by a period.
The group name does not support any of the following characters: " / ? [ ] , : \| < > + = ; ? * @ or ASCII characters in the range 1-31.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the local group. -
name- Name of the local group.
Related ONTAP commands
vserver cifs users-and-groups local-group create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
description |
string |
Description for the local group. |
members |
array[members] |
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
sid |
string |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method. |
svm |
Example request
"description": "This is a local group",
"members": [
"name": "string"
"name": "SMB_SERVER01\\group",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262278 |
Name is a required field. |
655399 |
CIFS server must exist to create a local group. |
655660 |
The operation is allowed only on data SVMs. |
655661 |
The group name and description should not exceed 256 characters. |
655668 |
The specified group name contains illegal characters. |
655675 |
The local domain name specified in the group name does not exist. |
655677 |
This operation does not allow for the creation of a group in the BUILTIN domain. |
655682 |
The group name cannot be blank. |
655717 |
The specified group name already exists. |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
href |
string |
_links
members
name |
string |
Local user, Active Directory user, or Active Directory group which is a member of the specified local group. |
svm
name |
string |
uuid |
string |
local_cifs_group
description |
string |
members |
array[members] |
name |
string |
sid |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
