Create a local group configuration for an SVM
Creates a local group configuration for a specified SVM to manage user access and permissions within the storage virtual machine environment. This is typically used to organize and control access to resources by grouping users together.
HTTP method and endpoint
POST /protocols/cifs/local-groups
Introduced in
ONTAP 9.9
Important notes
The group name can contain up to 256 characters.
The group name cannot be terminated by a period.
The group name does not support any of the following characters: " / ? [ ] , : \| < > + = ; ? * @ or ASCII characters in the range 1-31.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the local group. -
name- Name of the local group.
Related ONTAP commands
vserver cifs users-and-groups local-group create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
description |
string |
Description for the local group. |
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
svm |
Example request
"description": "This is a local group",
"name": "SMB_SERVER01\\group",
"svm": {
"name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262278 |
Name is a required field. |
655399 |
CIFS server must exist to create a local group. |
655660 |
The operation is allowed only on data SVMs. |
655661 |
The group name and description should not exceed 256 characters. |
655668 |
The specified group name contains illegal characters. |
655675 |
The local domain name specified in the group name does not exist. |
655677 |
This operation does not allow for the creation of a group in the BUILTIN domain. |
655682 |
The group name cannot be blank. |
655717 |
The specified group name already exists. |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
href |
string |
_links
members
name |
string |
Local user, Active Directory user, or Active Directory group which is a member of the specified local group. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
local_cifs_group
description |
string |
name |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
