Create local user configuration for an SVM
Configures a local user for an SVM, setting up authentication credentials for accessing the storage virtual machine. This operation is typically used to manage user access within your storage environment.
HTTP method and endpoint
POST /protocols/cifs/local-users
Introduced in
ONTAP 9.9
Usage notes
Creates the local user configuration for an SVM.
Important notes
The user name can contain up to 20 characters.
The user name cannot be terminated by a period.
The user name does not support any of the following characters: " / ? [ ] , : \| < > + = ; ? * @ or ASCII characters in the range 1-31.
The password must be at least six characters in length and must not contain the user account name.
The password must contain characters from three of the following four categories:
English uppercase characters (A through Z)
English lowercase characters (a through z)
Base 10 digits (0 through 9)
Special characters: ~ ! @ # 0 ^ & * _ - + = ` ? \| ( ) [ ] : ; " ' < > , . ? /
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the local user. -
name- Name of the local user. -
password- Password for the local user.
Default property values
If not specified in POST, the following default property value is assigned:
account_disabled- false
Related ONTAP commands
vserver cifs users-and-groups local-user create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
account_disabled |
boolean |
Indicates whether the user account is enabled or disabled. |
description |
string |
Description for the local user. |
full_name |
string |
User's full name. |
name |
string |
Local user name. The maximum supported length of an user name is 20 characters. |
password |
string |
Password for the local user. |
svm |
Example request
"description": "This is local user.",
"full_name": "user name",
"name": "SMB_SERVER01\\user",
"password": "string",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of local user records. |
records |
array[local_cifs_user] |
"records": [
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262278 |
Name and password are required fields. |
655399 |
CIFS server must exist to create a local user. |
655660 |
The operation is allowed only on data SVMs. |
655661 |
The user name should not exceed 20 characters. Also full_name and description should not exceed 256 characters. |
655665 |
The user name must not match the CIFS server name of the specified SVM. |
655668 |
The specified user name contains illegal characters. |
655675 |
The local domain name specified in user name doesn't exist. |
655682 |
The user name cannot be blank. |
655733 |
The password does not meet the password complexity requirements. |
655736 |
The specified user name already exists. |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
href |
string |
_links
membership
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
local_cifs_user
account_disabled |
boolean |
description |
string |
full_name |
string |
User's full name. |
name |
string |
password |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
