Create the local user configuration for an SVM
POST /protocols/cifs/local-users
Introduced In: 9.9
Creates the local user configuration for an SVM.
Important notes
The user name can contain up to 20 characters.
The user name cannot be terminated by a period.
The user name does not support any of the following characters: " / ? [ ] , : \| < > + = ; ? * @ or ASCII characters in the range 1-31.
The password must be at least six characters in length and must not contain the user account name.
The password must contain characters from three of the following four categories:
English uppercase characters (A through Z)
English lowercase characters (a through z)
Base 10 digits (0 through 9)
Special characters: ~ ! @ # 0 ^ & * _ - + = ` ? \| ( ) [ ] : ; " ' < > , . ? /
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the local user. -
name- Name of the local user. -
password- Password for the local user.
Default property values
If not specified in POST, the following default property value is assigned:
account_disabled- false
Related ONTAP commands
vserver cifs users-and-groups local-user create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
account_disabled |
boolean |
Indicates whether the user account is enabled or disabled. |
description |
string |
Description for the local user. |
full_name |
string |
User's full name. |
membership |
array[membership] |
Specifies local groups of which this local user is a member. |
name |
string |
Local user name. The maximum supported length of an user name is 20 characters. |
password |
string |
Password for the local user. |
sid |
string |
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method. |
svm |
Example request
"description": "This is local user.",
"full_name": "user name",
"membership": [
"name": "SMB_SERVER01\\group",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
"name": "SMB_SERVER01\\user",
"password": "string",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of local user records. |
records |
array[local_cifs_user] |
"num_records": 1,
"records": [
"membership": [
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262278 |
Name and password are required fields. |
655399 |
CIFS server must exist to create a local user. |
655660 |
The operation is allowed only on data SVMs. |
655661 |
The user name should not exceed 20 characters. Also full_name and description should not exceed 256 characters. |
655665 |
The user name must not match the CIFS server name of the specified SVM. |
655668 |
The specified user name contains illegal characters. |
655675 |
The local domain name specified in user name doesn't exist. |
655682 |
The user name cannot be blank. |
655733 |
The password does not meet the password complexity requirements. |
655736 |
The specified user name already exists. |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
href |
string |
_links
membership
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
sid |
string |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method. |
svm
name |
string |
uuid |
string |
local_cifs_user
account_disabled |
boolean |
description |
string |
full_name |
string |
User's full name. |
membership |
array[membership] |
name |
string |
password |
string |
sid |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
